Building a new 6DIY
Discussion in 'DIY Motion Simulator Projects' started by Flymen, Aug 22, 2018.
  1. SilentChill
    20,595Coins
    Enjoy dude !!!
  2. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    Hey,
    Dont Forget , if you want Your Beer colder , put your set up seize of your printer 3D at 105% !! Why ; like that you Can put like stirofoam inside all a round and bottom !!
  3. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    Looks good.
    My rig has been down for months. It needs a refresh.
    But, for that, I need time and money. The 2 principal missing parts right now.
  5. pmvcda
    15,446Coins
    So, are we getting some new videos soon?
  6. hannibal
    hannibal Active Member
    4,491Coins
    looks amazing @Flymen!
    i been hard at work too.
    today i just cut 72mm holes in quarter in plates, starting to change over to servo motor.
    i finished my power cabinet last week.. have to put some photos up
    also finished a controller with a mini screen for that upcoming apache simulator.
  7. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
  8. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
  9. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    So? Less noise? More stable?
  10. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    We will see it !!! For the moment it about 50% less noise and smooth for just one… if everything goes well in the future … I will change 5 others
  11. frosted123
    frosted123 New Member
    - 26Coins
    Hi @Flymen!
    Happy to see another quebecois in sim plateform. I am currently working on one also similar and I was wondering how tge actuator were attach on your setup. Is the bottom part of the actuator attach using a universal joint that does not rotate and top part attach with a ball joint that enable rotation? I saw somewhere else that 1 of the attachments point need to rotate. Best
  12. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Bienvenue Frosted123 (Je suis un Drummondvillois travaillant à Matane).
    My 6 DOF had a universal join at the bottom, not turning. At the top, is a piece similar to this. It is called a Helm's joint.
    Pierre.
  13. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    .Hi , you can put a bigger joint then my mine , like silentchilds with 3D print
  14. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    like this ...
  15. frosted123
    - 26Coins
    Thanks both!
    Another question, I saw somewhere something about an anti-wobble kind of ring that can be fix to the top of the ballscrew. Would one of you be able to share the design?
  16. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    550Coins
    Motion platform, 6DOF
    Hi, here is my version.
  17. Flymen
    Montreal, Canada
    2,434Coins
    DC motor, 6DOF
    It's better if you put a bearing like my last set up ( and two rod ) . the plastic Anti woble is a plaster . go for it with bearing like me or Silent child .
