Wagnard
Star Wars Squadrons XML (STEAM version ONLY) 4.2
Star Wars Squadrons XML plugin for 4.2
  1. Mechromancer
    434Coins
    Margolle, where you able to fix this??
    Many had similar problem at first. I will see my set up and try to tell you what I did.
  2. elvis77
    elvis77 New Member
    11Coins
    Hello . this plugin still works today
  3. elvis77
    elvis77 New Member
    11Coins
    no movement with this plugin! is it still functional?
  4. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    hi folks. just a fresh plugin an instructions, for new users on jun 2022 !
    YOU DONT NEEDs to uninstall anti cheat
    YOU DONT NEEDs to go offline.
    install plugin
    verify files integrity
    rename to starwarssquadrons_oldlauncher.exe
    open cmd ( admin ) and goes to squadrons ( install files of the game )
    EXAMPLE MINE: D:\Games\steam\SteamLibrary\steamapps\common\STAR WARS Squadrons
    COPY THIS COMMAND LINE AND ENTER: mklink starwarssquadrons_launcher.exe starwarssquadrons.exe
    OPEN NEW SIMBOLIC LINK, properties mark read only
    start from steam or simbolic link
    use 20 or 10 for surge
    tests on quest 2 vr ok 04 junho 2022 - 01:39
    gamevibe capture tuning center
    this is it ;)
  5. margolle
    margolle New Member
    50Coins
    hello.
    I do not speak English, it is very difficult to understand the details explained.
    moreover, the explanatory videos are in English, the words on the PCs are in English, there are also differences between windows (win7, win10, win11).
    I don't know how to solve the problem because there is too much detail badly translated by google translation.
    I would really like to not bother you with this anymore.
    I downloaded the paulopsx2 plugin.
  6. margolle
    margolle New Member
    50Coins
    my probleme by video.
  7. margolle
    margolle New Member
    50Coins
  8. paulopsx2
    brasil
    647Coins
    FIRST OF ALL, CREATE a new folder like "GAME" or whatever and than put your game in it
    Because "program files" folder its under protect.
    just try again
  9. MarkusB
    4,215Coins
    @paulopsx2, thank you for providing this new plugin.
    I would propose that you create a new thread for it, because handling two plugins in a single thread is very confusing.
  10. margolle
    margolle New Member
    50Coins
    video 2 impossible move
  11. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    hi @margolle i think you need to go to C:\WINDOWS\system32 find cmd.exe and copy it to the folder that you made and run it from there
    i dont own the game etc but i have mocked it up for the pictures
  12. margolle
    margolle New Member
    50Coins
    hi
    I tested, it tells me: the symbolic and already created impossible to redo one.
  13. margolle
    margolle New Member
    50Coins
    Pcture
  14. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    are you running cmd as admin?
  15. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    ok try this C:\WINDOWS\system32 and run cmd as administrator
    then type d: then press enter
    then cd D:\SteamLibrary\steamapps\common\STAR WARS Squadrons then enter
    then mklink starwarssquadrons_launcher.exe starwarssquadrons.exe
  16. margolle
    margolle New Member
    50Coins
    yes ; right click, run as administrator
  17. margolle
    margolle New Member
    50Coins
      97.2 KB
      298
  18. margolle
    margolle New Member
    50Coins
    Hello . If start starwars then game start, 1sec and crash .
  19. Rodrigomarcos1978
    Rodrigomarcos1978 New Member
    Brasil
    97Coins
    Hello.. Has anyone managed to use the plugin with this game purchased by Origin? I bought the Game from Origin. I've done everything described here, but the platform doesn't move, I spent more than 8 hours trying with all the possibilities.
    I used the first plugin posted here and also the last plugin posted by PauloPSX2. I created the link to the Laucher file through the CMD in admin mode, put the file read-only, uninstalled the anticheat, blocked the files in the Firewall, put the game folder isolated and out of Program Files, tried without internet, uninstalled and I reinstalled all Simtools and nothing worked..
    I think I did everything, but if anyone knows anything else, please let me know. I'm thinking there is a specific problem for the game purchased by Origin. PauloPSX2 himself was very attentive to me and tried to help me through TeamViwer, but he couldn't find the problem either. Anyone have an idea? Has anyone managed to use this plugin with a game purchased from Origin?
    152,541Coins
    +11,086 / 56 / -2
    I don't know about Origin, but can I check what the install path is and if the plugin requests you specify that install path when patching for motion?
