FlyPT Mover 3.5.8
  1. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,858Coins
    DC motor, 6DOF
    I am afraid you could do some misconception. Don’t forget that the accelerations are usually correctly transmitted from many games. In many cases, scaling and LPF/HPF filtering brings very convincing results
  2. Marco Annunziata
    919Coins
    Yes, true, actually this filter wasn't to get in conflict with the acceleration of the games but to substitute the games. I thought that I could simulate the acceleration I need with the loop module end sine wave type. I believe I could approach the acceleration of my actuators, doesn't need to be exactly the gravity acceleration.
    Thank you for your concern, always very precious your support
  3. RCFlyer
    RCFlyer Member
    139Coins
    Has anyone that is using MSFS2020 started getting crashes since the last MSFS2020 update on the 18th of November? I have been getting a FlyPT kernbase.dll crash once or twice a day with exception offset: 0x0003f29c; exception code: 0xc000041d. Just trying to understand whether it issue is FlyPT or MSFS2020.
  4. RCFlyer
    RCFlyer Member
    139Coins
    I am trying to tune my platform movements; quickness of response and level of harshness. Is it better to make adjustments in the input or out gain?
  5. dureiken
    dureiken Active Member
    1,254Coins
    any idea ? thanks :)
  6. Wanegain
    Wanegain Active Member
    Bruxelles
    2,019Coins
    Hello, is there a specific effect for the traction loss or do we have to do a series of calculations to get it?
  7. pmvcda
    15,812Coins
    On the next build, the pose module for traction loss is getting a big update.
    It's already making traction loss from slip angles or longitudinal/lateral speed ratio.
    I want to add slip ratio and wheel angular speed. Not sure they are good enough for that.
    Usually I use yaw speed to generate the rotation on the pose module, but made the above for testing.
    I also have RWASH on yaw position, that washes the yaw absolute angle to zero.
    There's many filters variations we can use.
    I have also tried the CUBIC3 to give some deadzone.
    Imagination is the limit, but I hope to have something easier to use in the next build.
    By the way, work is going on, but many changes and bugs are delaying it. Sorry.
  8. Mauricio
    Mauricio Member Gold Contributor
    75Coins
    [QUOTE = "VirtualObsession, post: 222783, member: 25567"] I'm not getting cuts with Move. I did it with SimTools and SimConnect. Telemetry seems to hit the FS2020's performance a little. So if you have performance issues anyway, this will make telemetry quite difficult. [/QOTE]
    I'm not actually having problems with performance. I'm running at 60fps with ease. The problem is with Heave. If I make it more "aggressive", to better capture the ascent and descent movements during the flight (plane in real life, it keeps moving all the time), as well as turbulence, the "unrealistic jerks" appear. In order for the flight to be cleaner, I am being forced to disable Heave. I believe there is some filter to improve this. I currently use Emalp
  9. Wanegain
    Bruxelles
    2,019Coins
    Currently I am using Simtools as Source for traction loss, and it works so I can wait for the next update :thumbs
    Another thing I have trouble adjusting is motion compensation. It's very hard to get something working correctly...
    I move the axis in SteamVR where my COR is, but it seems to be not the COR... Do I have to change something else for that to be the COR ?
  10. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,767Coins
    Hi Mauricio,
    I dont know, if this will solve your problem or suitable for your type of sim, but I want to throw in my current settings for heave.
    I had sleepless nights to find them, but now finally give me the real feeling of flying.
    Wickie
  11. Wanegain
    Bruxelles
    2,019Coins
    I just realized that I was not actually using Simtools for my traction loss (it was just high values so very smooth).
    I wanted to try with the data from Simtools, but I did not find the trace of the plugin for MMF with flyptMover. What is the configuration to do in Simtools so that it becomes a source in flyptmover? Or a link to the plugin for the interface?
    :cheers
  12. pmvcda
    15,812Coins
    Here: https://www.xsimulator.net/community/threads/flypt-mover.13464/page-3#post-180938
    But what source are you using in simtools?
  13. dureiken
    1,254Coins
    @pmvcda no idea ? :(
  14. hexpod
    berlin
    7,858Coins
    DC motor, 6DOF
    This small bug was reported already and the fix fill show up in the upcoming release I guess.
  15. dureiken
    1,254Coins
    ok thanks nice :)
  16. RCFlyer
    RCFlyer Member
    139Coins
    So....is no one other than me experiencing FlyPT crash issues?????
  17. Wanegain
    Bruxelles
    2,019Coins
  18. pmvcda
    15,812Coins
    The file should be included in the normal download.
    If not, download an old version on the first post here.
  19. pmvcda
    15,812Coins
    Not having problems on my side
  20. RCFlyer
    RCFlyer Member
    139Coins
    Thanks for the reply. The issue started with last update for MSFS2020. I get a crash almost once daily. Same error code.
