Showroom IL2 Sim on 2 Dof
Discussion in 'DIY Motion Simulator Projects' started by xmcnodx, Nov 30, 2021.
  1. xmcnodx
    xmcnodx IL2 Sim with 2Dof
    Schmelzer
    Zirndorf Deutschland
    94Coins
    Hello everyone, I'm new here and I'm trying to build a 2Dof Sim,
    Unfortunately my English is translated as I don't know, I'm not bad at tinkering, but I struggle with electronics and Arduino, but I hope for a good success with your support
  2. xmcnodx
    Schmelzer
    94Coins
    In order to realize my project, I started buying the necessary materials.
  3. xmcnodx
    Schmelzer
    94Coins
    Yesterday came Arduino uno R3
  4. xmcnodx
    Schmelzer
    94Coins
    Yesterday also the ordered potentiometers arrived 10K
  5. xmcnodx
    Schmelzer
    94Coins
    tomorrow i expect the rest of my delivery and will post it, i am already looking forward to the construction.
  6. xmcnodx
    Schmelzer
    94Coins
    To realise my project I started to buy the necessary materials.
  7. xmcnodx
    Schmelzer
    94Coins
    DHL arrived early and another part arrived, the most expensive part so far and difficult to find the universal joint, and the connecting cables as well as the VNH2SP30 board.
  8. xmcnodx
    Schmelzer
    94Coins
    At the weekend I will try the cable and a test engine to see if it works, I hope so.
  9. xmcnodx
    Schmelzer
    94Coins
    what an unexpected turn of events, my son gives me his
    gamer chair.
    I accept it with pleasure and a big conversion awaits me to turn it into a flight simulator.
  10. xmcnodx
    Schmelzer
    94Coins
    Help when I transfer code to Arduino I get this error message.
  11. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
  12. xmcnodx
    Schmelzer
    94Coins
    Hello Skuldi thank you I have installed it on Arduino and no error message came, now I can continue, thank you again,
  13. xmcnodx
    Schmelzer
    94Coins
    Today I prepared the displacement to carry out a test, but unfortunately there was no movement on the motor.
  14. xmcnodx
    Schmelzer
    94Coins
    have taken over all settings from @RufusDufus
    I also noted that Arduino Com3 and SMC3Ut. is also on Com3.
      274.5 KB
      217
  15. xmcnodx
    Schmelzer
    94Coins
    I have applied all the settings as described. What I have noticed is that when I move the potentiometers of motor 1 or 2, the green lines move but the motor does not.
  16. xmcnodx
    Schmelzer
    94Coins
    I add a few pictures of my settings
  17. xmcnodx
    Schmelzer
    94Coins
    Where could my error be that the test engine does not move, of course the engine was checked for function.
    Please help.
  18. Skuldi
    Germany NRW
    265Coins
    something between the arduino and the monster shield. the monster shields are cheap and often broken. did you try the other side (B1/B2)? can you test with a multimeter?
    for the future: if you want to use your seat for flying i would suggest FlyPT instead of Simtools.
    Its a little harder to set up but you get some nice features like different profiles for on ground and in air.
  19. xmcnodx
    Schmelzer
    94Coins
    151,467Coins
    +11,039 / 56 / -2
    First test the MM, as @Skuldi notes they are often faulty: https://www.xsimulator.net/community/faq/monster-moto-testing-before-use.158/
    Make sure the pots are connected to the motors, as the pots provide positional feedback.
    Don't just copy settings, follow the SMC3 setup instructions to dial in the settings for your hardware: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Don't bother messing with SimTools until SNC3 is fully sorted and working as expected.
