FlyPT Mover 3.5.3
  1. pmvcda
    15,702Coins
    I think everyone is strugling with this.
    Just as a reminder, we get full roll/pitch in aircrafts and rollercoasters. This is something we can ignore for cars (not yaw).
    Because of this I made some more filters.
    The idea is to wash the value, we want to feel the acceleration, but when she becomes zero or the speed is constant, the rig should go back to 0º.
    So, one of those filters is RWASH (R for rotating, you also have WASH).
    It washes the value to zero on rotations, ignoring the transition from -180 to 180º.
    It has the following parameters:
    RWASH(VALUE;a,b,c)
    where:
    VALUE is the value we are filtering (should be roll or pitch position in this filter!)
    a is the entry smoothenes:
    b is the exit smoothenes
    c is the history used, or the amount of the last values received we use.
  2. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    Hi @pmvcda , would you be adding support for Forza Horizon 5? Thanks
  3. pmvcda
    15,702Coins
    Already works with the Forza4 source.
    Roll and Yaw speeds are swapped. Corrected for the next build
  4. BondeX
    EE
    Michigan, USA
    1,501Coins
    Thanks, I will try it.
  5. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Is "Follow pretend pose even out of range" working correctly with virtual motion compensation? I'm experiencing motion compensation glitches when pitched back to the limit. For example, when accelerating during takeoff. The motion compensation appears to reset to centre momentarily, so I'm viewing the back of the pilot's seat. Constant movement appears to be working though.
  6. pmvcda
    15,702Coins
    Follow pretended pose is for the next build.
    Not in curent public build.
    But it should solve the problem of being out of range and VR
  7. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    Excellent stuff. Thanks for your hard work!
  8. pmvcda
    15,702Coins
    I wanted to release this week, but it's complicated...
    To many changes under the hood...
    One of them made me go through all the sources again!
    So took the chance to get some extra data in most of them...
    And we are now getting the frequency of the data:
    Compairing MMF to UDP in PCARS2.
    UDP at 60 hz
    MMF associated to frame rate
    Let's see if I can release. Still many loose points.
    • Like Like x 6
  9. VirtualObsession
    IT developer
    Hertfordshire, UK
    280Coins
    This is very interesting to know. So MMF is giving better frequency. I wonder how FS2020 compares to DCS and IL2, which feel super smooth.
  10. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi @Thanos and @pmvcda
    I am using the mover-interface and MSFS20 directly without simtool.
    Since a long time I am searching for a reason, why I have sometimes a kind of rough motion. This is very subtile, but when flying in MSFS20, I sometimes feel a rough motion, specially at long strokes.
    Last week I encountered that when I change the settings for "Interval loops" (in the OUTPUT::SERIAL - window) and "calculation rate" (in the Options-window), I can make the same rough feeling even (much) stronger. So my Idea was that it could be a kind of timing-issue between mover-interface and PC or MSFS20....
    Today I continued searching for this topic and found an older post from Thanos where he mentioned that he saw a "stepping" movement when using mover-interface directly (old version v1.3), but a smooth motion when using the mover-plugin in SimTools.
    So before I start reading through the whole thread of mover interface to find an answer, I kindly want to ask if this topic was solved, or if I should give the SimTools-mover-plugin a try?
    Thanks!!!
    Wickie
  11. pmvcda
    15,702Coins
    So, this is one of the reasons in the delay for the next build.
    I made big changes on the outputs. I'm now using a new method to generate the byte array we send out to the hardware. It's easilly 100 times faster.
    I noticed that in some slower machines it was hanging.
    But this brought an hell of bugs, because everything is interconnected in Mover. Still solving some related to that change.
    What I also found and can't solve for now is that the rig modules are to heavy.
    The update of data in that window (specially the lower panel) causes an interruption on the calculation thread.
    So the work around there, is to hide the rig modules or at least the lower panel of the rig modules.
    This is specially the case of 6dof rigs, where we have info for 6 actuators...
    Made some changes there to, but it's not enough.
    The problem with the SimTools plugin is that it can't save the setups and is limited in many aspects compared to the actual Mover.
    • Informative Informative x 4
    • Optimistic Optimistic x 1
  12. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,839Coins
    DC motor, 6DOF
    Maybe applying couple of ms delay to gui refreshment in some modules would make it faster ?
  13. hexpod
    berlin
    7,839Coins
    DC motor, 6DOF
    I don’t think we need those values coming with such a speed
  14. RCFlyer
    RCFlyer Member
    139Coins
    Is simtools needed to run flypt with dofreality h3 or can flypt be used stand alone?
  15. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,509Coins
    flypt can be used stand alone for any games listed in the 'Sources' section of Mover
  16. deadlymanager
    deadlymanager Member
    11Coins
    In the Aerofly FS2, the accelerations are very discrete, tell me how to smooth out into a smooth curve and not lose the reaction speed of the platform?
    I Have SPIKE(LOGISTIC(EMALP(VALUE;2000);50;0.9);1;2000;2) but very slow/
  17. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I have three questions on FlyPT Mover is it compatible with the arduino code I use on simtools, it works with an arduino uno + saberthoot and finally I am looking for presets for f1 2021 thank you very much
  18. pmvcda
    15,702Coins
    The EMALP(VALUE;2000) creates lot's of lag. 2000 is to high.
    Please try to replace it with a BUTTERWORTHLP(VALUE;5;1)
    5 is the frequency in hz and 1 the order of the filter.
    Please try some variations on that.
    The butterworth should respond faster to the signal.
    You can also try to replace the EMALP just with DEMALP or TEMALP and see if it's enough.
  19. pmvcda
    15,702Coins
    It works, just use the same settings in the serial output module
  20. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, so the same setting as simtools I test thank you.
