Question output arm shake problem
Discussion in 'SimTools DIY Version' started by yangsqr, May 11, 2020.
  1. Gadget999
    12,035Coins
    set pmw min to zero
    set pwm max to 255
    set pwmrev to 255
  2. yangsqr
    yangsqr Member
    - 21Coins
    Please take a look:
  3. MarkusB
    4,215Coins
    Well, it looked better before.
    But each rig is very unique and needs individual settings. So just play with the parameters and check which combination works best for you.
    The link provided by @noorbeast is very helpful for getting a basic understanding.
  4. Gadget999
    12,035Coins
    it is pretty good
    set
    P = 400
    I = 1
    see what happens
  5. yondwangmms
    yondwangmms Member
    - 149Coins
    Different motors need different PID settings! I'll send you my settings for your reference.
    kp=200
    ki=1
    kd=300
    ks=80
    pwmmin=5
    pwmmax=200
    pwmrev=200
    deadzone=1
  6. Captain Jack
    Captain Jack Member
    - 26Coins
    pwmmax is basically how much power you want to use. Setting it to 255 means that your motors can run up to 100% power. If you leave it at 200, you are using up to 80% of motor power.
    Some pwmmin may help, I found that 20 is a sweet spot with wiper motors on my rig. I'm also running 255 pwmmax to use all of the available power.
