My very cheap 2dof
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Dec 15, 2021.
  1. SteULM
    SteULM Active Member
    601Coins
    Hi everyone here is my very cheap rig finished, this was my first creation in this field and I wanted to thank everyone in this community for all the tips and tricks they have posted. I would never have been able to build it without everyone's help.
    I started with the design and construction of the coupling gears between the motor and the potentiometer.
  2. SteULM
    601Coins
    3D printing and coupling with motors.
  3. SteULM
    601Coins
    Test with SMC3
  4. SteULM
    601Coins
    I plugged the Arduino Uno and the two IBT-2 drivers into a PC power supply box
  5. SteULM
    601Coins
  6. SteULM
    601Coins
    I begin the work of creating the station ....
    I have to be able to keep the costs very low !!
  7. SteULM
    601Coins
    The base with fixed wheels ...
    Also cut off the top and presented all the components before fastening them and connect the two parts
  8. SteULM
    601Coins
    And tried to make them move ...
  9. SteULM
    601Coins
    Once the seat has been mounted, now remains the pedals and the console for the steering wheel and drilled a series of holes to adjust the pedal board...
  10. SteULM
    601Coins
    I cut 18mm diameter tubes and welded plates to create the support for the steering wheel and painted with acrylic spray.
  11. SteULM
    601Coins
    Mounted the shelf that supports the steering wheel
  12. SteULM
    601Coins
    mounted the steering wheel in a comfortable position for the whole family but later I studied a way to adjust it
  13. SteULM
    601Coins
    video of the first test with Simtools ....
  14. SteULM
    601Coins
    Black edition...
  15. SteULM
    601Coins
    They asked me for the gear files I used for 3D printing, can I put them in a zip / rar file and attach them here?
  16. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    Yes you can upload a zip file directly, as long as it is not too big.
  17. SteULM
    601Coins
    Here are the stl files of the gears I drew, they are 16 and 32 teeth.
    I only posted the gears because the support is different for each engine.
  18. SteULM
    601Coins
    Modification to the pedal support, now it is no longer a truck ...
  19. SteULM
    601Coins
    I also post the media files because I have been asked.
  20. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    sorry to bother you again. I posted here because its not relevant on your another thread.
    can you share your smc3 and simtools settings? I need to do some benchmark to tuning my own setup.
    thx in advance !
