Bug Need to keep restarting Simtools for it to connect and enable motion
Discussion in 'SimTools DIY Version' started by Tino.Sturlic, Dec 15, 2021.
  1. Tino.Sturlic
    Tino.Sturlic Member Gold Contributor
    199Coins
    Hello.
    I'm having a problem with Simtools.
    Every time I start the simulation I need to restart simtools for motion to activate. It just beeps and it does not connect.
    Sometimes it works sometimes I need to restart it 20 times to work. Once it starts working its stable as long as I'm in the game/simulator. When I exit sometimes it works but most of the time I need to keep restarting it until it finally starts again.
    Can you please help me?
    This is my motion sim
  2. yobuddy
    51,524Coins
    Scn's?
    Are you using a usb hub?
    Chat soon,
    153,728Coins
  4. Tino.Sturlic
    199Coins
    I'm not using a hub. I tried different USB ports. Everything is directly plugged in the PC motherboard. once connected it never disconnects or loose connection as long as I am in the sim. that's why I would not say it's USB bandwidth problem.
    153,728Coins
    Have you checked for port conflicts?
    Have you actually run something like UsbTree to map all your USB devices?
  6. yobuddy
    51,524Coins
    And you using SCN actuators?
  7. Tino.Sturlic
    199Coins
    No I did not. Can you please recommend what software to install (link) and maybe a few quick words what to do with it? Thanks.
  8. Tino.Sturlic
    199Coins
    No, i am using servo actuators and 4 in 1 servo driver from PT factory and Thanos AMC-MDBOX interface.
    153,728Coins
  10. Tino.Sturlic
    199Coins
    This is how it looks. I tried different USB host controllers. Now it's alone on it's own host controller and it still doesn't work every time.
  11. Tino.Sturlic
    199Coins
    Is there any kind of debugger for this? Now it just lost connection in the middle of the race... :(
  12. yobuddy
    51,524Coins
    I have a AMC-MDBOX setup here and it seems to be working fine.
    I did have to update the firmware on my thanos controller when I received it, but I was an early adopter, so it may not be your problem.
    May I see a pic of your interface settings?
    Take care,
  13. Tino.Sturlic
    199Coins
    I tried with different usb cable. Did not solve the issue. What does that beep sound means. It makes that sound during startup of the game engine every time it's not working. I was also updating Thanos interface I believe. It was working fine for some time without problems...
  14. yobuddy
    51,524Coins
    It means SimTools was not able to startup an interface.
    Try with an update rate of 10ms and see what happens buddy.
    @Thanos, any ideas buddy?
  15. Tino.Sturlic
    199Coins
    Could it be because neither of my usb ports is 2.0? they are all 3.0...
    Just tried with 10ms, didn't help :(
  16. yobuddy
    51,524Coins
    No, I don't believe so.
    Hopefully @Thanos will jump in soon with some ideas.
  17. Thanos
    Electronics Engineer
    2,907Coins
    If you have a spare USB hub with external power supply, try to connect the AMC-MDBOX on that alone. Could be USB motherboard driver issue. Using USB hub bypasses that and uses generic USB hub driver. External power supply for the hub also helps as the AMC-MDBOX uses a bit more power too.
    Something like this would work good:
    Powered USB Hub, atolla 4-Port USB 3.0 Hub with 4 USB 3.0 Data Ports and 1 USB Smart Charging Port, USB Splitter with Individual On/Off Switches and 5V/3A Power Adapter www.amazon.com/dp/B083XTKV8V/ref=cm_sw_r_awdo_navT_g_VCBYBKN9M3YK416XSMFY
  18. Tino.Sturlic
    199Coins
    Thanks Thanos. I will try that.
  19. Tino.Sturlic
    199Coins
    I tried powered USB hub and unfortunately it does not help.
    This is how it looks with powered USB hub
  20. Thanos
    2,907Coins
