Question No movement in SimTools
Discussion in 'SimTools DIY Version' started by evolaco, Oct 3, 2021.
  1. evolaco
    evolaco Member
    Spain
    694Coins
    Hello, I have not used simtools for a long time and now it does not work, I have movement from SMC3 but in simtools nothing moves, the com ports are correct and I have not changed anything since the last time it worked.
    151,467Coins
    +11,039 / 56 / -2
    What version of SimTools are you using, this is the latest: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    Likely a bit more context is needed.
    How did you verify the com port?
    Are you running SMC3 and SimTools at the same time?
    What are your Axis Assignments?
    When you say "in simtools nothing moves", do you mean in Output Testing?
    Have you tried temporarily disabling your fire wall and antivirus to check if either are interfering with communications?
  3. evolaco
    evolaco Member
    Spain
    694Coins
    I have done tests and with the output testing it works, but I enter assetto corsa and nothing moves, then I exit and it stops working in output testing too, when I close the application and reopen it it works again, but only in the test until I re-enter the game.
    151,467Coins
    +11,039 / 56 / -2
    If Output Testing works then it is likely a configuration issue, so please post pictures of all of your settings.
    Have you un-patched the re-patched AC for motion?
  5. evolaco
    evolaco Member
    Spain
    694Coins
    It stops working just by opening steam or Content Manager, then if you close them it doesn't work if you don't restart simtools, I don't understand anything.
    With SMC3 it always works, something strange happens.
  6. yobuddy
    50,750Coins
    Are you using 2 arduinos to connect the sim to the PC?
    I believe you only need 1 interface setup for 3 axes.
    The interface - output should look like this:
    [A<Axis1a>][B<Axis2a>][C<Axis3a>]
    I would remove interface #2 and change the interface - output for interface #1 to match the above string.
    Take care,
  7. evolaco
    evolaco Member
    Spain
    694Coins
    I use 2 aeduinos because one is behind the seat and the one with the loss of traction under the platform
  8. yobuddy
    50,750Coins
    Can we have a pic of your simulator?
    I'm guessing you have 3 axes?
    But all 3 axes can be driven from a single arduino.
    But if you wish to use 2 arduinos, the Interface output of both need to be:
    Chat soon,
  9. tadek
    tadek Active Member
    574Coins
    I have the same problem..
    All is ok in SMC3
    settings in smc3
  10. tadek
    tadek Active Member
    574Coins
  11. tadek
    tadek Active Member
    574Coins
    phew now it's ok
  12. nanofico
    nanofico New Member
    - 24Coins
    problem with simtools. output testing doesn't work and game doesn't work. smc3 configuration done and positive motor test. simtools version 2.5
  13. noorbeast
    151,467Coins
    +11,039 / 56 / -2
  14. nanofico
    nanofico New Member
    - 24Coins
    here they are
  15. yobuddy
    50,750Coins
    The bit range should be 10 for SMC3.
    Then in output testing try using the '(a) Axis Output' under output type.
    Take care,
  16. nanofico
    nanofico New Member
    - 24Coins
    The strange thing is that until 2 days ago it worked well even in the simtools test. So I started configuring for live gaming for speed and the game data is simulated but the motors don't move as previously written.
    151,467Coins
    +11,039 / 56 / -2
  18. nanofico
    nanofico New Member
    - 24Coins
    Yes, I also made a few laps. Closed the game and patched
  19. yobuddy
    50,750Coins
    Is there axis assignments for Live for Speed.
    I only see settings for the default profile so far is why i ask...
  20. nanofico
    nanofico New Member
    - 24Coins
    solved at this time. i uninstalled simtools and reinstalled again by downloading it from the official site and it magically worked
