Question 2dof with traction loss in the future
Discussion in 'DIY Motion Simulator Projects' started by Michael Yoshi, Dec 25, 2021.
  1. Michael Yoshi
    Michael Yoshi New Member
    95Coins
    Can you guys double check my work before I pull triggers? I plan to use an Arduino uno with the following:
    Motor drivers 2x
    Power supply with room for the eventual 3rd "dof"
    2x of these jazzy motors from eBay https://www.ebay.com/itm/223503181516?hash=item3409d3e6cc:g:YGkAAOSweaFczGIG
    The hope is to get some heims and a ujoint from my used car parts and weld this all together. Eventually upgrade from 2dof to a setup with traction loss. This will be for drifting sims.
    The power supply seems weird to me. The motors draw a handful of amps but their total watt usage is much higher than the amp and volt math work out to be. Does this parts list look ok? Am I missing anything?
    153,986Coins
    +11,161 / 57 / -2
  3. Michael Yoshi
    95Coins
    Oh I guess I'm too new to the forum so it removed all but 1 link. Server psus don't sound bad but 24v 200watt supplies are like $30 new
  4. Michael Yoshi
    95Coins
    Oh peak 1200watt. Oof
