DIY Compact 6DOF Wiper 24V <200EUR
Discussion in 'DIY Motion Simulator Projects' started by tadek, Nov 13, 2020.
Tags:
  1. tadek
    tadek Active Member
    616Coins
    Hi
    current state of construction
    more and more fears and a lot of doubt ...
  2. tadek
    tadek Active Member
    616Coins
  3. tadek
    tadek Active Member
    616Coins
  4. tadek
    tadek Active Member
    616Coins
    system for operating 2 actuators
    I have to make 3 such arrangements
  5. tadek
    tadek Active Member
    616Coins
  6. tadek
    tadek Active Member
    616Coins
    according to the scheme
  7. RacingMat
    21,047Coins
    hi!
    A threaded pot directly into the motor shaft, looks quite dangerous...
    During the setup phase, you will have to wire the pots (red and black wires) accordingly to motor rotation (red and black wires), if wrong : the pot will break...
    During the testing phase, many things could go wrong (code, wiring...) and break the pot...
    I'd strongly advise you to use a coupling between pot and shaft.
    have a look there https://www.xsimulator.net/community/threads/from-atoz-2dof-arduino-wiper-playseat.4616/#post-45420
    and there is a flat part against the pot to prevent its rotation ;)
    yours
  8. Gadget999
    12,035Coins
    if you have trouble with the ibt2's look at my 6d0f build I found some awesome 100A(200A temporary) drivers
  9. tadek
    tadek Active Member
    616Coins
    Hi
    Thank you RacingMat for the hint
    I know that I can not make a mistake with the electrical connection (polarity) of the potentiometer because I will damage it immediately.
    In the future I want to use Hal's potentiometers.
    greetings
  10. tadek
    tadek Active Member
    616Coins
    Friends I have a question :sos
    Which cables should be shielded?
    Is it enough to shield only potentiometer cables?
    Should the cable shield be connected to ground?
    best regards
  11. Billel
    Billel Member
    195Coins
    Hello tadek,
    what's your current status with the build, i'm thinking of building a 6dof platform with wiper motors, i likes your idea of dual motors for each axis to double the torque, did it work ?
    Best regards.
