Building my first DIY wheel and 2DOF motion Project
Discussion in 'DIY Motion Simulator Projects' started by itsumairu, Jan 2, 2022.
  1. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    439Coins
    Hi everyone, this was my first creation in this field and I wanted to share to you all, and hope I can get some feedback cause I just started to gather some material to build my own 2dof motion.
    and I thank everyone in this community for all the tips they have posted. I would never have been get the courage to start it without everyone's help.
    I started with the design and gather some material that I need.
    used cheap motor, the seller say it was a wire feeding mechanism dc motor, hope it can do the job.
    just get this morning, 2 IBT-2 , and arduino uno.
    And I'm gonna use this aluminum size 3030 and 3060 to build my rig. hope I can utilize its rigidity and light weight.
    and I want to share my finished DIY wheel, using STM32 and EMC pro utilities for the software.
    254150465_10220002810405555_4396739802029504693_n.jpg 254164660_10220002810045546_4940877150525695908_n.jpg
    still a long journey, and cant wait till all of the material arrived.
    sorry for my english. feedback is very welcome
  2. itsumairu
    Psychologist
    Indonesia
    439Coins
    little update, done with the potensio mechanism.
    use my son's cheap lego wheel and wrap it with Timing Belt HTD3M. works great.
  3. itsumairu
    Psychologist
    Indonesia
    439Coins
    Update, done with the electronic.
    Not a tidy work, or clean build, but hope it can do the job.
  4. itsumairu
    Psychologist
    Indonesia
    439Coins
    Another update..
    Testing smc3 software done. The motors work fine.
  5. itsumairu
    Psychologist
    Indonesia
    439Coins
    Short clip for the movement.
    It's so rough.
    Still figuring out how to make it smooth.
  6. itsumairu
    Psychologist
    Indonesia
    439Coins
    finally testing phase on LFS.
    you can see the feedback is so rough. Its so scary to be on it.
    I have to decrease a lot of force to make it ride able.
    need some help and tips to make itu smoother. thx.
    Screenshot 2022-01-07 112125.jpg Screenshot 2022-01-07 112101.jpg smc3 settings.jpg
    151,608Coins
    +11,043 / 56 / -2
    See the FAQ motion profile tuning tips here: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    You have not included it but likely you need to capture the Tuning Center Max/Min values and then tune from there. Keep in mind the the BIGGER the value the smother the motion, over a larger axis range, and the SMALLER the TC value the sharper the motion, over a smaller axis range.
  8. itsumairu
    Psychologist
    Indonesia
    439Coins
    Thx @noorbeast for the fast reply. Gonna double check the FAQ and report it here
  9. itsumairu
    Psychologist
    Indonesia
    439Coins
    A question, at this poin can I aplly to get a free license of simtools @noorbeast?
    151,608Coins
    +11,043 / 56 / -2
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the rig testing phase.)
    • Have been a member of the community for at least 30 days.
    So in your case your project meets most of the criteria, except membership for at least 30 days.
  11. itsumairu
    Psychologist
    Indonesia
    439Coins
    for this do I have to turn on the motor? or leave it off?
    thank you again!
    151,608Coins
    +11,043 / 56 / -2
    You leave motion enabled when refining a motion profile. If your base settings are way too harsh manually change the Tuning Center to higher values and then capture Max/Mins, followed by tweaking to suit personal preferences.
  13. itsumairu
    Psychologist
    Indonesia
    439Coins
    *update. Installed my DIY wheel base and sequential shifter.
    next is building new base for my pedals.
    hope can get it done soon.
  14. itsumairu
    Psychologist
    Indonesia
    439Coins
    Hi all.
    Been playing LFS for about 15minutes just for testing, the motor and bts2 motor driver get warm.
    So I wonder if you all that build 2dof motion can share your experience, and for how long the motor can be used, until it get too hot?
    Sorry for my English. Hope you all can understand it well.
  15. seuszok
    Poland
    465Coins
    Dont hurry up with licence, this truck on LFS demo i best to configure sim.
    I try to do my rig as quick as posible to get licence and try other games ... I instal dirt rally immediately... but if You dont learn how adjusting rig before on LFS ... than rig will try to kill You :D:D:D
    but seriously you can add an extra ibt for the motor and replace the potentiometers with hall sensors. Sensor cables should probably be well shielded. in mine I will change because one motor heats up excessively and only the cable passes by the ibt in the difference with the mirror motor.
  16. itsumairu
    Psychologist
    Indonesia
    439Coins
    lol.. I agree with you. first time I get on, it nearly throw me to side.
    yes, now I get a get more smooth experience after read the guide that @noorbeast give me.
    btw, how much ibt should I used for 2 motor? its not enough 1 each for the motor?
    and yes, I'm in a thigh budget so potensio at the moment, maybe in a near future I'll upgrade it to hall sensor.
    and I wanna share a little update after I equip it with my pvc DIY pedals.
  17. seuszok
    Poland
    465Coins
    I found on forum information about 2 ibt2 on one motor (that was inspired from guide about monster moto shield - not offer in Poland and low quality from China -information from other threats)
    I was go that way after burn several of them , later when all was runing they have hot a lot.
    You can look on my threat I was try describe as much I can. I was focus on points when I stop and "waste" time to serch how to.
    Halls are cheap if You go to print housing :)
    You done guide about Your diy whell its interested, propably is more powerfull than g29?
    Regards
  18. itsumairu
    Psychologist
    Indonesia
    439Coins
    Will check your thread. Thx again for the feedback.
  19. itsumairu
    Psychologist
    Indonesia
    439Coins
    a video of me, playing through LFS, to test the effect and crash effect. so excited! it bring my sim rig to another level! thx again for the guidance @noorbeast and everyone on this community, for sharing every information that I need.
    now I'm gonna install my DIY bass shaker to the rig. to get more feedback from the road and engine revving.
    151,608Coins
    +11,043 / 56 / -2
    Congrats on getting your rig moving :thumbs
    Try manually setting differentiated Max/Min values in the Tuning Center for Surge, that should give the effect of snappy gear changes: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
