Showroom IL2 Sim on 2 Dof
Discussion in 'DIY Motion Simulator Projects' started by xmcnodx, Nov 30, 2021.
  1. xmcnodx
    xmcnodx IL2 Sim with 2Dof
    Schmelzer
    Zirndorf Deutschland
    94Coins
  2. xmcnodx
    Schmelzer
    94Coins
  3. xmcnodx
    Schmelzer
    94Coins
  4. xmcnodx
    Schmelzer
    94Coins
    when i move the podi this is the result and motor turns like left and right and stops
    153,830Coins
    +11,151 / 57 / -2
    SMC3 must be properly configured and working as expected before messing with SimTools.
    You can't run SMC3 and SimTools at the same time, it will cause a port conflict.
    The SimTools Tuning Center shows game data, so that part looks fine, but you need to sort out your hardware and SMC3.
  6. xmcnodx
    Schmelzer
    94Coins
  7. Skuldi
    Skuldi Member Gold Contributor
    Germany NRW
    265Coins
    Do you hear a "peep" when you turn on the sim tools output test?
  8. Skuldi
    Germany NRW
    265Coins
    click on Sine and see if something moves
      136.1 KB
      596
  9. xmcnodx
    Schmelzer
    94Coins
    @noorbeast thank you I thought it had to run with everything I even ran Arduino program with it
    today i will test it thanks :)
  10. xmcnodx
    Schmelzer
    94Coins
    yesterday I could still hear a "beep" when I switched on the output test of the SIM tools, today I don't hear any I don't know why
    153,830Coins
    +11,151 / 57 / -2
    I am guessing the beep was a USB disconnect notification.
  12. Skuldi
    Germany NRW
    265Coins
    Yes, you get a beep when simtools can not connect with the arduino.
  13. xmcnodx
    Schmelzer
    94Coins
  14. xmcnodx
    Schmelzer
    94Coins
    since today i get this error message
  15. xmcnodx
    Schmelzer
    94Coins
    System.ComponentModel.Win32Exception (0x80004005): Nur ein Teil der ReadProcessMemory- oder WriteProcessMemory-Anforderung wurde abgeschlossen
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.5.1
    Win32 Version: 0.2.5.1
    CodeBase: file:///I:/Simulator%20Ordner/SimTools2/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///I:/Simulator%20Ordner/SimTools2/SimTools/Game_PluginAPI.DLL
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  16. xmcnodx
    Schmelzer
    94Coins
    have followed what @yobuddy wrote down unfortunately no result
    You might try this if, under Win10, you uninstall the
    3.5.Net framework via "Switch Windows functions on or off" and reinstall and check.
    Please follow these steps.
    A. Press Windows + R keys, type appwiz.cpl in the run window and press Enter.
    B. Click on "Enable or disable Windows features".
    C. Disable ".NET Framework 3.5 (includes .NET 2.0 and 3.0)" and then click OK. This may take some time.
    D. Now click ".NET Framework 3.5 (contains .NET 2.0 and 3.0)" and then click OK.
    Translated with www.DeepL.com/Translator (free version)
  17. Tom1980
    Tom1980 The Sky Is The Limite
    Business Management
    Alabama, USA
    26Coins
    Where did you pick up your ujoint from?
  18. xmcnodx
    Schmelzer
    94Coins
    in germany ebay classified
    ebaykleinanzeige
  19. xmcnodx
    Schmelzer
    94Coins
    because of the NET Framework problem i have completely deleted simtools and reinstalled all inputs and yes i have a signal my small test motor jumped from left to right in the game as well as in simtools when testing output
    the NET Framework problem appears but everything still works
    anyway i am happy that it works now i can go on and order the engines
    153,830Coins
    +11,151 / 57 / -2
    Good that you are making progress, but you likely need to resolve the .NET issue, as it will probably affect game plugins.
