2Dof project, motors do not move ...
Discussion in 'New users start here - FAQ' started by Alexandre Da Cunha, Jan 9, 2022.
  1. Alexandre Da Cunha
    Alexandre Da Cunha New Member
    Production supervisor
    - 1Coins
    Hello when I increase PWmMax the motors do not move, I have Kp at 400 .... But nothing happens ... can they kill me?
    153,986Coins
    +11,161 / 57 / -2
    Can you please post pictures of all of your settings and also outline what hardware is being used.
  3. Alexandre Da Cunha
    - 1Coins
    The hardware I use is the following, practically the same here: (SMC3Utils v1.01 - tool - Arduino code - SMC3.ino - https://goo.gl/adkztn) and I followed this procedure for the assembly and parameterization. Captura de ecrã 2022-01-09 170531.png Captura de ecrã 2022-01-09 170645.png Captura de ecrã 2022-01-09 170743.png Captura de ecrã 2022-01-09 170856.png Captura de ecrã 2022-01-09 170939.png Inked_20210916-065413_AliExpress_LI.jpg
  4. Alexandre Da Cunha
    - 1Coins
    After a few tests the engines moved 1/4 of a turn in the opposite direction of each other, but nothing more. Captura de ecrã 2022-01-09 183624.png
    153,986Coins
    +11,161 / 57 / -2
    The pot line needs to be in the middle when the motor is in its at rest position, are yours?
  6. Alexandre Da Cunha
    - 1Coins
    What is the line of posts in green?
    153,986Coins
    +11,161 / 57 / -2
    Sorry, the pot line in SMC3 is green, it should be in the middle of the SMC3 graph when the motors are in their rest position (rig is level).
  8. Alexandre Da Cunha
    - 1Coins
    Hello I inverted the 5V and GND cables on the potentiometer and on motor 1 the green line is in the center, but on motor 2 and 3 it is a little deviated, what can I do to align them? Captura de ecrã 2022-01-10 122607.png Captura de ecrã 2022-01-10 122657.png
    153,986Coins
    +11,161 / 57 / -2
    With the motor in its rest position loosen the coupling connecting the motor to the pot, turn the pot until the green line is in the middle, then re-tighten the coupling.
  10. Alexandre Da Cunha
    - 1Coins
    Thanks the lines of the 3 engines are aligned, I increase PWmMax but they don't move, can I launch simtolls with the game?
    153,986Coins
    +11,161 / 57 / -2
    SMC3 must be properly configured and working as expected before you mess with SimTools.
    SimTools can be configured to launch at Windows startup.
  12. Alexandre Da Cunha
    - 1Coins
    The green lines are all aligned, I set Kp at 400 and then I go up PWmMAX little by little but the motors don't move. What could be going on so that the engines don't move?
  13. Alexandre Da Cunha
    - 1Coins
    153,986Coins
    +11,161 / 57 / -2
  15. Alexandre Da Cunha
    - 1Coins
    Will the cable I solder to the brush connect to the ground of the power outlet?
  16. Alexandre Da Cunha
    - 1Coins
    I understand, sorry, I pass the negative straight to the brush...
  17. Alexandre Da Cunha
    - 1Coins
    I have already disconnected the motor body insulation, positive at fast speed, but I still have the problem that when I turn on the current one motor starts and does not stop. the other does not move.
    SMC3utils looks like this:
