Question SMC3 with limited range potentiometers
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by RJ Stausebach, Jan 11, 2022.
  1. RJ Stausebach
    RJ Stausebach Member Gold Contributor
    Ireland
    325Coins
    I have not found anything on this in the forums so hope someone can point me in the right direction.
    I have set up SMC3 with Mode2 and after some setting up can run two cheap 50N electrical actuators with potentiometers off it. The feedback is limited though and not centred when looking at the graphs in SMC3utils. This is because the potentiometers have a limited turn over the 50mm stroke of the actuators. They run roughly from 3.5kOhm to 6.5kOhm over their full 10kOhm range, so say from 350 to 650 with a center of around 500.
    Is there a way to scale this so I get a full response, eg. the 300 range available gets scaled to 1024 (or 250 as the case might be) in the SMC3 code or elsewhere?
    Also the center actually seems offset to one half, so running at say the quarter top of the graph, not sure why.
    This is the setup:
    the graph green line is indicative of the perceived center position of the actuator, at this point it wasn’t running yet so ignore the rest.
  2. Gadget999
    12,035Coins
    how did you fit the pots ?
  3. RJ Stausebach
    Ireland
    325Coins
    151,991Coins
    +11,061 / 56 / -2
    At 10mm/s they are really, really slow and not really suitable for motion sims, you want at least fifteen times that speed for a direct actuator, or some similar mechanical design multiplication for indirect use: https://www.xsimulator.net/community/faq/speed-needed-for-good-motion.218/
  5. RJ Stausebach
    Ireland
    325Coins
    Thanks Noorbeast, sounds like back to the drawing board for me! :think
  6. Gadget999
    12,035Coins
    You might be able to change the gearing to make them faster
    Can you turn the lots by hand to see if the green line moves in smc3 ?
  7. RJ Stausebach
    Ireland
    325Coins
    I could get them to run and move the green line but only in part of the top half. I would have liked to have scaled the inputs in SMC3 to react to a full range of movement, something I am sure is possible. You could also change the gearing but changing the program inputs would be a whole lot easier. None of which means much if they are too slow to adequately provide motion simulation…
  8. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Thanks for posting this as i was looking into trying this just saved me some money.
  9. RJ Stausebach
    Ireland
    325Coins
    Hi Martin, you’re welcome. The ones I have are”high speed” at 40mm/s. Ut as the man said you want at least 150mm/s.
    Anyone looking for a box of 10 off 50mm stroke actuators with pots? :think
    151,991Coins
    +11,061 / 56 / -2
    You may want to consider using some for compact electrically controlled adjustable seat, pedal and/or wheel position. Speed does not matter for creature comfort projects ;)
  11. RJ Stausebach
    Ireland
    325Coins
    Thanks Noorbeast! :thumbs
