6dof project with low cost wiper motors and 24V IBT-2
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Jan 12, 2022.
  1. SteULM
    SteULM Active Member
    613Coins
    Hello everyone, after reading and rereading the NjMotion post
    https://www.xsimulator.net/community/threads/prototype-6dof.5045/
    I decided to try to replicate it starting with a voltage of 12V because I already have three 12V 30A power supplies in the house and if they are not enough, I will power everything at 24V which I have already tried and everything works.
    Here is a video of the test:
  2. SteULM
    613Coins
    I have just finished preparing and mounting the gears of the potentiometers to the motors, the last two should arrive on Friday.
  3. SteULM
    613Coins
    I also removed the capacitors from the motors to isolate them.
  4. SteULM
    613Coins
    This is how the lower base should look with the motors inserted, as long as it can weld the metal otherwise I will have to ask someone capable for help
  5. SteULM
    613Coins
    While for the control part I will use 3 Arduino UNO R3 with two IBT-2 modules for each one.
  6. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    438Coins
    Hello mate, it's really a nice build.
    I have a question. Can you share in detail how you attached the 3d printed gear to the motor, and its possible that you share the files. I use a similar motor, and really want to revise my potensiometer mechanism to a better one, and yours is better I think. Thx in advance
  7. SteULM
    613Coins
    • Friendly Friendly x 2
  8. SteULM
    613Coins
    On the opposite side of the rotation pin I drilled a hole with ISO 5mm thread and I screwed a screw with Allen head passing through the gear.
  9. itsumairu
    Psychologist
    Indonesia
    438Coins
    Thanks for your quick response. Will check your thread.
    Sorry maybe its not relevant, but is it your 2dof rig still functional?
    How about its performance, for how long can you play on it before it get too hot?
    Sorry for my English
  10. SteULM
    613Coins
    Yes my 2dof still works and also very well, the performances are excellent for that I pushed myself to try to build this 6dof with the same materials. Engines become barely warm but after a couple of hours of use.
  11. SteULM
    613Coins
    This morning I managed to finish the levers for the engines, I set up the connection to the rods at 40 and 60 mm from the center of the engine pin so I can increase or decrease the stroke.
  12. SteULM
    613Coins
  13. SteULM
    613Coins
    In the afternoon I try to finish the job even on the last two scooters that arrived and then for the iron I have to wait for the outcome of the covid-19 test at the weekend to be able to go and get it.
  14. SteULM
    613Coins
    Well, today I started working on the control part ...
  15. SteULM
    613Coins
    Almost finished the control box, if I can take the test in the afternoon.
  16. SteULM
    613Coins
    Ok, control box finished and working.
  17. SteULM
    613Coins
    Test of the last of the six motors/axes. Now unfortunately I have to stop because to go and get the materials for the construction of the platforms (iron) I have to wait for the end of the covid-19 quarantine. :(
  18. fzxj520
    fzxj520 Active Member
    1,341Coins
    I think you may need to use the spring reasonably or as shown in the figure below
  19. SteULM
    613Coins
    Wow, what a great idea .... If that's the case I'll try to imitate you :thumbs
  20. SteULM
    613Coins
    Finished axis setup on Simtools and movement test.
