  1. Quang Thuy
    Quang Thuy New Member
    87Coins
    I have solved the problem. The cause is reverse connection of 2 pins 01 and 02 of BTS7960 43A. A simple mistake, but took up quite a bit of my time.
  2. mikethemotionguy
    mikethemotionguy learning daily Gold Contributor
    mechanic
    - 3Coins
    hello guys i new to all the forum stuff so please be patient with me!!
    I follow dmax on YouTube and built my rig because of his videos. Now the only thing i did different was put my motors up front, and my motors are mirror image motors! So trying to figure out which ways need to be up and down is being a challenge but ill figure that out later as the 2 front motors work perfectly. my issue is with the 3rd motor for traction loss everything seems to be wired correctly and the motor only moves one way!!! the green line confirmed follows the blue so the pot and the motor seem to be wired correctly as it doesn't lose control all the way to one side or anything!! i know i had reflashed the arduino before when getting the front motors working correctly and forgot to set it to mode2 for the ibt controllers and they would only move one way like the 3rd motor is doing now!! any ideas???
    151,979Coins
    +11,061 / 56 / -2
    So to be clear, if you are using ibt controllers the SMC3 code needs to be edited for Mode 2.
    Other than that the pot and lever need to be central in the TL axis range when configuring SMC3 settings.
  4. mikethemotionguy
    mechanic
    - 3Coins
    thanks for the reply!! it is for sure in mode 2 or the front motors wouldnt work but one way!! I did get the orientation correct for the front motors and as for the rear 3rd motor pot is centered when rig is centered and it works pefectly on the up side but has no response on the down side im baffled confirmed the wiring is correct disconnected everything and ohm tested for continuity and all test were good idk whats going on!!
    151,979Coins
    +11,061 / 56 / -2
    To provide proper context please start your own build thread and detail all aspects of the settings and hardware used.
  6. Tom1980
    Tom1980 The Sky Is The Limite
    Business Management
    Alabama, USA
    26Coins
    Good Evening Folks, what potentiometer are you folks using. I have used a few but they dont work right. My feed back or green line always stays at the top of the SMC window so the motors wont engage.
    151,979Coins
    +11,061 / 56 / -2
    I use 180 degree Hall sensors, like these: https://au.element14.com/bi-technol...fs/sensor-hall-0-2v-20v-to-10v-pin/dp/2319662
    However, is there any actual reason you believe your pots are the issue? The most common error with pots is wiring.
    But with SMC3 issues there can be a range of other potential causes, such as hardware faults.
  8. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I am using the following from Amazon, I just think I got the wrong ones.
    WayinTop 5pcs 360 Degree Rotary Encoder Module KY-040 Brick Sensor Development Board with Push Button for Arduino
  9. tadek
    tadek Active Member
    616Coins
    hi Tom1980
    You should use a potentiometer with a resistance of 10 kom.
    Encoder is not a potentiometer.
    Ancncoder is an impulsor.
    Best regards
  10. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    Hi. Awsome tutorial. As a brand newbie just in the "gettin a bur under my butt to build one", your step by step walkthrough layed it out and made it feel alot less dounting. Can I use this system with linear actuators?
    151,979Coins
    +11,061 / 56 / -2
    These days for linear actuators most have moved from DC to servos to power them, then use a specific controller like the one by @Thanos, which make the servos pretty much plug and play. So while you could great SMC3 controlled actuator it is not really worth the bother.
  12. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Thank you for this detailed guide it has helped me to progress in my project again thankyou.
  13. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Battery Bank
  14. Tom1980
    Business Management
    Alabama, USA
    26Coins
    20220107_183448.jpg 20220107_183607.jpg 20220107_202834.jpg 20220107_183448.jpg
    Wiring harness hookup
  15. Tom1980
    Business Management
    Alabama, USA
    26Coins
    CIRCUIT board assembly
  16. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I need some help, I am having great difficulty in getting windows Smc to power my motors. I have tested the controllers and motors and am using the coding from the 3.dof page. What is happening is the feedback green line goes directly to the bottom. I am using the POT from digikey but just can't get the green line to get off the bottom. Any help would be greatly appreciated. Have a good night.
    151,979Coins
    +11,061 / 56 / -2
    Is the pot centered when the motors/lever are in their rest position?
    When they are, make sure the motors are not powered, disconnect the pot, rotate it by hand until the line is in the middle of the SMC3 graph, then reconnect it.
  18. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Thanks for the advise I am going to try different rotations.
  19. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I wish I knew what I was doing wrong. I moved the POT around several times and still cant get the feeedback line off the bottom. Does anyone have any other advice or suggestions.
  20. Tom1980
    Business Management
    Alabama, USA
    26Coins
    This is what it keeps doing, any suggestions would really be awesome.
