Question Simtools output testing communication problem
Discussion in 'SimTools DIY Version' started by GTexas, Jan 16, 2022.
  1. GTexas
    GTexas New Member
    Houston, TX
    465Coins
    Simulator
    1. DIY: Seatmover
    2. DOF (Number of axles ): 2
    3. Actuators (DIY, SCN5 etc.): Wheelchair motors with Sabertooth 2x32
    4. Interface (Arduino, SCN, Mega, DIY etc. ): Arduino Uno
    SimTools
    1. Version Number: 2.5.1
    2. Game Plugin where the error is happening: Output Testing
    3. Settings: Sabertooth baud rate 115200, 0.1 ms. No jumper from pin 8 to GND on Arduino
    4. Using @BlazinH SPS 8.2 Softstart
    5. Axis assignment as per SimTools manual, see screenshot
    6. Interface setting serial 500,000, N,8,1 as per manual, Interface Output [A<Axis1a>][B<Axis2a>]
    7. Same COM4 in SMC3 Utils and Simtools
    8. Setting SMC3 Utils to UDP passthrough
    Running the motors from SM3 Utils works fine. Only thing that puzzles me is that it shows Arduino SMC3 ver 0.80 even though I use the latest SPS 8.2 sketch from @BlazinH
    Problem is when try to go to output testing. The little color box in the Game Engine next to the DIY license indicator goes from orange to blue, but not green. When I move the sliders in output testing nothing happens.
    I have checked the interface settings several times, but something seems to keep Simtools from communicating with the SMC3 Utility. Please see below screenshots. Any ideas?
    SMC3Utils working.jpg Axis Assignment.jpg no axis limiting.jpg interface settings.jpg output testing.jpg
    153,986Coins
    +11,162 / 57 / -2
    Check if other programs such as anti-virus or firewall are interfering with communications.
    Temporarily disable anti-virus or firewall, reinstall the latest version of SimTools and test in Output Settings.
  3. yobuddy
    51,557Coins
    Scn3 needs this i believe [A<Axis1a>][B<Axis2a>][C<Axis3a>]
  4. GTexas
    GTexas New Member
    Houston, TX
    465Coins
    I only had time to disable the firewall, but that did not make a difference. Will try reinstalling SimTools tomorrow.
    In what mode has SMC3 Utils to run, monitor or UDP Passthrough when SimTools is on?
    Will the Output Testing from the Game Engine work without the Game Manager running?
  5. GTexas
    GTexas New Member
    Houston, TX
    465Coins
    Do I need to state all 3 axis even though I have only two assigned?
    My current Interface Output Setting is [A<Axis1a>][B<Axis2a>] only.
    153,986Coins
    +11,162 / 57 / -2
    Mode 1 for SMC3.
    Make sure you do not run SMC3 and SimTools at the same time, as that will create a port conflict.
    Output Testing will work with just Game Engine, but there is no good reason not to run Game Engine and Game Manager at the same time.
    [A<Axis1a>][B<Axis2a>] is correct for 2DOF.
  7. GTexas
    GTexas New Member
    Houston, TX
    465Coins
    Reinstalling SimTools did help, thanks. Output testing is working now. I am using a Sabertooth, so I think I need to run Mode 3, not 1. I also noted that if I run SMC3 Utils first, then stop it and then run the Game Engine one motor is not always responding. When I restart the computer and start right away with the Game Engine everything works fine. Anyhow, I got a working system now and will proceed with the next steps. Thanks for your help.
    153,986Coins
    +11,162 / 57 / -2
  9. GTexas
    GTexas New Member
    Houston, TX
    465Coins
    Confirmed, I am using the SPS Softstart from BlazinH from the thread you referenced, my earlier post was not clear in that respect. It is working fine and I got LFS with the motion simulation running as expected. Will work on patching other games next.
  10. luu trung
    luu trung Member
    172Coins
    [QUOTE = "noorbeast, post: 224642, member: 10786"] Check if other programs like anti-virus or firewall are interfering with communication.
    Temporarily disable anti-virus or firewall program, reinstall latest SimTools version and check in Output Settings. [/QUOTE]
    why when opening simtool shows a message when not connected to the internet? so internet "simtool" is required to work
    153,986Coins
    +11,162 / 57 / -2
    You can expand the error and copy and past the full error.
    You could try reinstalling the .NET Framework: http://www.microsoft.com/en-us/download/details.aspx?id=17851
    If the problem persists Backup, uninstall SimTools (answer yes to "remove old settings and files"), and then reinstall SimTools: http://www.xsimulator.net/community...thout-loosing-your-profiles-and-settings.160/
  12. luu trung
    luu trung Member
    172Coins
    System.Net.Sockets.SocketException (0x80004005): An invalid argument was supplied
    at System.Net.Sockets.Socket.Send(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags)
    at System.Net.Sockets.UdpClient.Send(Byte[] dgram, Int32 bytes)
    at SimTools_GameManager.frm_GameManager.SendText_GameEngine(String text)
    at SimTools_GameManager.frm_GameManager.frmMain_FormClosing(Object sender, FormClosingEventArgs e)
    at System.Windows.Forms.Form.OnFormClosing(FormClosingEventArgs e)
    at System.Windows.Forms.Form.WmClose(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at SimTools_GameManager.frm_GameManager.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4515.0 built by: NET48REL1LAST_C
    Assembly Version: 0.2.5.1
    Win32 Version: 0.2.5.1
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4536.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
    Win32 Version: 4.8.4435.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AMS2_GamePlugin
    Assembly Version: 2.0.0.2
    Win32 Version: 2.0.0.2
    CodeBase: file:///C:/Users/Admin/AppData/Local/SimTools/GamePlugins/AMS2_GamePlugin.dll
    AssettoCorsaCompetizione_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Users/Admin/AppData/Local/SimTools/GamePlugins/AssettoCorsaCompetizione_GamePlugin.dll
    ForzaHorizon5_GamePlugin
    Assembly Version: 2.0.0.1
    Win32 Version: 2.0.0.1
    CodeBase: file:///C:/Users/Admin/AppData/Local/SimTools/GamePlugins/ForzaHorizon5_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 Version: 2.1.0.0
    CodeBase: file:///C:/Users/Admin/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    ProjectCars3_GamePlugin
    CodeBase: file:///C:/Users/Admin/AppData/Local/SimTools/GamePlugins/ProjectCars3_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  13. yobuddy
    51,557Coins
    This is a socket error...
    System.Net.Sockets.SocketException (0x80004005): An invalid argument was supplied.
    Maybe your running the smc3 app at the same time?
    (All I can think of is a conflict.)
  14. luu trung
    luu trung Member
    172Coins
    when i disconnect from internet this new error build up? everything is normal when there is internet. Is "sim" required to have internet or do I need to reinstall "sim".thanks
  15. yobuddy
    51,557Coins
    No, you only need internet for registering.
    But looks like you are using the network interface plugin.
    So trying to send data while not connected to a network may cause a problem.
    What do your interface settings look like in SimTools?
  16. luu trung
    luu trung Member
    172Coins
    my interface looks like this. i still don't understand what is startup output and shutdown output? please explain more
  17. yobuddy
    51,557Coins
    The Startup and Shutdown outputs are there should your interface need something sent for startup or shutdown. Are you using the SMC3 sketch on an Arduino?
  18. luu trung
    luu trung Member
    172Coins
    hi .why does the feedback line fluctuate up and down like this????
  19. sci666
    1,210Coins
    i have a quastion about the movements in output testing to... i didnt really find it in the pdf manual as well.
    i have a 6DOF stewart and it seems that some movements in my config are the wrong way around ...
    so in which direction should the sim go if i push the test sliders to the right (!)
    -Yaw : Front to the left or right ?
    -Heave: up or down
    -Sway: left or right- i guess right ?
    -Pitch: front up or down ?
    -Roll: left or rigt - also guess right ?
    -Surge: forward or backwards ?
    thanks :D
    153,986Coins
    +11,162 / 57 / -2
    Please see the FAQs here: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
