help me pls
Discussion in 'New users start here - FAQ' started by Bob the builder, Jan 10, 2022.
  1. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    @noorbeast I think i might have narrowed down what code is on the arduino im waiting for him to send me some picture's he had emailed to him to confirm, if so it might be the emailed guide is for 1.3 version of simtools fingers crossed its as easy as adding the letter a :thumbs
    152,523Coins
    +11,084 / 56 / -2
    That would do it in an upgrade from 1.3 to SimTools 2. Of course if that is the case all plugins are also affected, as SimTools 2 plugins are not backward compatible.
    Thanks so much for devoting your time, expertise and energy in assisting @Bob the builder, helping each other out is what makes this an awesome community :thumbs
  3. Bob the builder
    Bob the builder New Member
    120Coins
  4. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
  5. Bob the builder
    120Coins
    when i turn on output testing it automaticly goes right. it barley moves and in not the correct direction.
    New settings
  6. Daguru
    Kitchen installer
    Wales uk
    468Coins
    Motion platform
    it looks as if its @RacingMat code the emailed instuctions @Bob the builder was sent match racingmats instructions we have now added the "A" to make it work with simtools 2.0 and have movement in output testing but only small and side to side @noorbeast
    i have not used this code so not a clue what to try next :(ive used smc3 and jrk only
  7. Bob the builder
    120Coins
  8. Bob the builder
    120Coins
    also i know it has to be hex i change it by mistake
  9. Bob the builder
    120Coins
    and if any one want to talk discord and not talk becouse i just dont rly understand everything
    152,523Coins
    +11,084 / 56 / -2
    I am pretty sure @RacingMat will help out when he gets a moment, or someone else who uses the code.
    As I understand it in Interface Settings the Output- Bit Range should be 8.
    And the setup instructions are here: https://www.xsimulator.net/community/threads/arduino-code-for-4dof-and-1-dirpin-hbridge-board.4614/
  11. Bob the builder
    120Coins
  12. RacingMat
    21,057Coins
  13. Bob the builder
    120Coins
    these are my settings / out put testing is kinda working but going all around ranom
  14. Bob the builder
    120Coins
    @RacingMat
    should i ping u everytime i respond or just respond and wait ?
  15. Bob the builder
    120Coins
    also its hex forgot to change it
  16. RacingMat
    21,057Coins
    I can't help you step by step as I'm really busy (2 jobs currently) and my sim is stored dissassembled
    and even if it's slow, you need to read and re-read manual and explanations to increase your personnal knowledge first hand :)
    keep going even if it's sometimes frustrating
    yours
  17. Bob the builder
    120Coins
    i read and re-read manual and explanations and nothing. @RacingMat
  18. 0v3rkill
    0v3rkill Member
    Programmer
    Netherlands
    - 269Coins
    if you run the test application does it show the motors going into protect? maybe the pot meter is broken or disconnected
  19. Bob the builder
    120Coins
    oh i forgot to close this threat i fixed it
  20. Gadget999
    12,035Coins
    what was wrong ?
