PLC based servo motor controller
Discussion in 'SimTools compatible interfaces' started by SoftKitty, Feb 11, 2021.
  1. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    Hello, everyone, last year I finished my first 2dof project by the help of Xsimulator community, and after that I shared all the details in a domesitc social media of my country, lots of people showed interest and helped me to improve with their knowledge.
    Servo motors are definitely a best power source for motion simulator, but there are not many affordable and easy to use interfaces available.
    Luckily in my follower group, a guy from a PLC manufacture figured how to use his industrial Programmable Logic Controller that is compatible with simtools to run servo motors.
    In this thread, I will share the most basic version that can run 4 motors(there are models that can run up to 10), and hopfully you can give some advises to let us make it better.
    My SFX100 looklike rig and actuator build will be introduce in project thread later.
    To see the functionality of the PLC please do watch the video below, sorry for my bad English.
    I will explain if you wish to know more about this.
    Thanks. BKai (aka SoftKitty)
  2. katy77
    katy77 New Member
    73Coins
    AC motor, SimAxe, Arduino, Motion platform
    Hi there,
    I am also trying to use PLC to build my simulator, would you please tell me how did you communicate flypt to PLC?
    I appreciate you if you can help me with that!
    Best regards,
  3. katy77
    katy77 New Member
    73Coins
    @SoftKitty can you please help me with this case?
  4. Fraza44
    Fraza44 Member
    Pensacola, FL
    652Coins
    Did anyone ever get an answer on how to communicate flypt to PLC from @SoftKitty? Did he share the code with anyone?
  5. Gadget999
    12,066Coins
    are you controlling the servo drivers using voltages and direction pin ?
  6. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    The code was developed with a friend of mine, at the moment we won't share it, it's on sale with the PLC controller in our country.
    The purpose of this thread is letting people know this kind of solution exists.
    I can answer the basic principle of communication: it uses serial port, almost the same with the SMC3 setup. The key is letting the PLC read the serial data and send into actions.
  7. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    I'm using the pulse+dir mode. similar with thanos AMC controller.
    the only difference is I'm using open collector wiring instead of differential wiring.
  8. Fraza44
    Fraza44 Member
    Pensacola, FL
    652Coins
    I'm new to allot of this stuff but I'm working on a plan for my own personal simulation platform.
    So if I understand what you are stating here, your "Programmable Logic Controller that is compatible with simtools to run servo motors" is capable of working with the smaller 6 Axis Industrial Robot such as Kuka, Fanuc, and ABB?
    Can you provide the website which sells your product so I can do more research?
    Also can you provide pricing for your package? (I hope this isn't against the rule to ask)
  9. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    Yes, it's by which most of the servo motors are driven in industrial applications, PLC is like a drive signal generator for them.
    The PLC I use is made by Samkoon, its coding lanuage is very similar to Siemens PLC.
    I'm not sure about the rule either, I will PM you the price information.
  10. MarkRSmith
    MarkRSmith New Member
    17Coins
    AC motor, Arduino, 6DOF
    I have a few of these Schneider LMC 20s. I'm willing to share some with anyone who can help with getting them up and running/communicating with Simtools.
    thanks
    Mark
  11. spikedbat
    spikedbat New Member
    Automotive Test Engineer
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    Hey,
    I bought a 4 actuator rig of a local sim cafe operator. It's new and from China. It's not branded.
    Long story short the guy doesn't know anything technical and his employees who do are away on an extended vacation back to China.
    MY problem is I have a Samkoon FGRS-C8X8T-4/4 PLC controller which is running the drives.
    I cannot get the rig to run in testing. I believe my problem is with the Interface Output string in Interface Setting.
    I've tried the combinations that were told to me which they are running at the cafe such as
    <Axis1a>A<Axis2a>B<Axis3a>C<Axis4a>D etc, and various combination of this. Looked in the manual for the Samkoon PLC which is pretty generic and can't figure out what string I need in there to get the PC to communicate with the controller.
    I'm hoping you guys maybe have some input on what I can try. I found your post from search Samkoon and this really is the only time that type of PLC controller is mentioned on this forum.
    I'm trying to set this up in V3.
    Any help would be greatly appreciated.,
  12. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    any pictures of your rig? I would like to check what its motors and touch screen look like.
  13. spikedbat
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    Here are some pictures of the setup.
  14. spikedbat
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    No touch screen on this PLC controller. I have not plugged into it yet as of now but i'm thinking I should?? I think I need to download some software off Samkoon's site.
  15. spikedbat
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    Oh one last thing to mention, when I go into test mode, all 4 actuators do stand up and start, but nothing works in the test other than that.
  16. spikedbat
    Ontario, Canada
    58Coins
    SCN6, 4DOF
  17. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    Yours looks similar to what I used, but I'm not sure what is coded inside, so I can only give you my settings and let you have a try.
    The touch screen can set some parameters like the speed of the actuators and how much the rig reacts to inputs from PC.
    If the person who sold you this has used the rig before, the parameters are less likely to remain zeros so I guess you can use without the touch screen.
    The Samkoon soft and manuals wouldn't help you, because that's all about how to code it, your problem is to set the interface and match the code inside the PLC.
    If so most of your setup is correct, the controller has got some input(not correctly) from the you PC simtools.
    Here is my interface settings:
    ComPort No. should be set as what you saw on your "device manager"
  18. spikedbat
    Ontario, Canada
    58Coins
    SCN6, 4DOF
    Okay yeah I've tried that but not upto 6 axis.
    I will try entering the info as you have and give it a try.
    152,977Coins
    +11,116 / 56 / -2
    What are the specifics of the v2 interface, that need porting to v3 Beta?
