FlyPT Mover 3.5.3
  1. Marco Annunziata
    889Coins
    Hi everyone,
    There is a way to emulate an acceleration ramp? Sice my rig has long extension and hight speed I need control the acceleration time in order to exploit thiese performance trying to recreate the G force.
    Thank you a lot
  2. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,755Coins
    Hi @pmvcda !
    Last week I downloaded the h-135 and h-145 helicopter from hype performance group and now I try to work out a good motion profile for this helicopters.
    One thing I was not able to solve, is getting some kind of motion that corresponds to the rotor-rpm. I tried to use the rpm output from msfs20, but this is the rpm of the gas-turbine, that is around 30000 rpm - so much too high for the rotor-rpm.
    In "pose from rpm" I can not set a filter in order to transform or divide this rpm down to a slower rotor rpm. For examle 1/1000.
    Maybe there is any solution or workaround for this? Would be really great ! Thanks!
    Wickie
  3. Avee
    Avee Virtual Pilot
    1,167Coins
    How about GAIN(VALUE;0.001) for division by 1000?
  4. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,751Coins
    DC motor, 6DOF
    Over 800mm you can accelerate at 9,81 during 04s. BUT at this point you’ve used the whole travel and you didn’t start to decelerate.
    https://www.calculatorsoup.com/calculators/physics/displacement_v_a_t.php
  5. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    so if the max speed of an actuator is 1m/s we can simulate 1G acceleration over a displacement of 5cm. That’s the limit.
    someone corrects me please if I am wrong.
  6. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    What ramp do you have in mind in order to emulate acceleration?
  7. Dirty
    All the way up front.
    7,951Coins
    I think you just have to select the right filter for the job. For longitudinal acceleration that should be an H1L2 type of filter (as I call it) or "EMALP(EMALP(EMAHP(Value)))" as it is described in Mover.
    This filter system will effectively feel like an acceleration ramp together with a "washout".
    Try it out... let me know how it feels.
    Btw, are you that death defying dude sitting on this GINORMOUS (!) monster of a super-long-stroke 6DOF rig that rattles like a bag of steel tubes that I saw on YouTube? :-D
  8. Historiker
    9,208Coins
    Link?
  9. Dirty
    7,951Coins
    I finally found the videos:
    And I thought I was brave already... :D
    ...but it looks like this is not @Marco Annunziata 's rig. I was just assuming, because of the italian sounding name and mentioning of the loooooooooong stroke :)
    • Funny Funny x 2
  10. Historiker
    9,208Coins
    Haha, sorry. I meant to request that via PM. Getting old sucks
  11. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    High pass 1st order Low pass 2nd order (H1L2). I like Mercedes Sprinter codename.
  12. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    It is indeed crucial to use the second order if you want a gentle and fast ramp.
    you can visualize the principe here :
    2A2FF9BF-ADE8-4E3E-86CF-BEAADED7581D.jpeg B2832774-D53D-441A-A51F-F13A4BD7AB97.jpeg
  13. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    @pmvcda - In FS2020 when I lift the front wheel in Cessna the back of the platform is lifting. Do we need an inversion in the suspension module ? Could we double check it ?
  14. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    I have trouble connecting to elite dangerous. Could someone help plz ?
  15. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    Resolved, I was able to get the motion in Mover through Elite Dangerous SimTools plugin
  16. Carelsbergh_Stijn
    Carelsbergh_Stijn Member
    Belgium
    450Coins
    Hello
    I want to go from the old flypt to the new one (I know I'm late) but I have a few questions, is it correct that the zero position used to be in the middle of the actuator and now is at the botom? I used to use a USB output to the odrives and I want to do this again, do I still have to use a certain number of bits to output the position?
    Thanks in advance.
    Carelsbergh Stijn
  17. Marco Annunziata
    889Coins
    Hello hexapod, I'm sorry for the late answer, thank you for your effort for help me, the ramp u need us a linear ramp, a constant acceleration rampwhere in order to emulate the 9.81 m/s2.
  18. Marco Annunziata
    889Coins
    Hello Dirty, yes right that's me, that's my YouTube channel where I publish my progresses with this rig and soon I will have ready the components for my second prototype with some issues solved like shakings and noise. Later I will sove these problems of this rig as well
    https://www.youtube.com/channel/UCx-6hmyPHwUF9S3h2u5o1jw
  19. hexpod
    berlin
    7,751Coins
    DC motor, 6DOF
    This (1G) you can achieve only over couple of centimeters, than you will reach the top speed of your actuators and the rest of the motion will have a constant speed (not constantly accelerated speed).
    To measure if you reach 1G, the best way is to measure it with phyphox software on your smartphone. Just attache the phone on your rig and see if 1G is reached.
  20. Jasper Janse van Rensburg
    Jasper Janse van Rensburg New Member
    58Coins
    Hi all. I am really a newbie at motion platforms, but a planning a DCS rig. My concern is the VR compensation. Long story short, if I cant get that to work, it will significantly influence my way forward. If not, I will stick to very small translations to reduce the shifts, while still experiencing some accelerations and vibrations. I have followed the instructions but don't note anything while in DCS with OVRMC running. It however seems this is done via steamvr. I use an occulus so it uses native support and not steam. Is this my problem?
