Game vibe no rpm change
Discussion in 'Dirt Series' started by tobias court, Jan 27, 2022.
Tags:
  1. tobias court
    tobias court New Member
    Sheet metal worker
    Uk
    4Coins
    Hi everyone im having trouble getting game vibe to change rpm output. I get tick over rumble but nothing else when accelerate ect. Can anyone help me
    Im playing dirt 2
    153,986Coins
    +11,162 / 57 / -2
  3. tobias court
    Sheet metal worker
    Uk
    4Coins
    Here is my settings
  4. tobias court
    Sheet metal worker
    Uk
    4Coins
    Doing it now
  5. tobias court
    Sheet metal worker
    Uk
    4Coins
    Did u get pics as it says i need atleast 3 posts to upload pics
  6. tobias court
    Sheet metal worker
    Uk
    4Coins
  7. tobias court
    Sheet metal worker
    Uk
    4Coins
    Here are my settings
    153,986Coins
    +11,162 / 57 / -2
    There does not seem to be game data for RPM, @yobuddy when you get a chance could you please check this:
  9. tobias court
    Sheet metal worker
    Uk
    4Coins
    There is maybe not on this specific pic tho. In green box i get rpm output
  10. tobias court
    Sheet metal worker
    Uk
    4Coins
    It was just to show settings
  11. yobuddy
    51,557Coins
    It looks like your Hi/Low settings may be the problem, with the Low setting being higher than the Hi value.
    For a test, set the Low value to 1000 and the Hi value to 9000 and see what happens.
    Chat soon,
  12. tobias court
    Sheet metal worker
    Uk
    4Coins
    Now you have pointed that out its clearly obvious. Thankyou.
  13. tobias court
    Sheet metal worker
    Uk
    4Coins
    Hi even tho it seems to work im not getting much differance. I have had an oscilloscope on the out put and it seems to change.
    The amp im using is for a sub in a car and my output is going into the low input. Do you think this is my problem? I also have a preamp in the system.
  14. tobias court
    Sheet metal worker
    Uk
    4Coins
    Sorted now thanks for your help didnt realise i could test ut with the slider at the top
