  1. tadek
    tadek Active Member
    574Coins
    hi Tom1980
    can you send a picture of your potentiometer
    Best regards
  2. Tom1980
    Tom1980 The Sky Is The Limite
    Business Management
    Alabama, USA
    26Coins
    This is the one I am using. I got it from digikey
  3. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Thank you Tadek for responding so quickly.
  4. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I am using the Elegoo mega, I wonder if it isn't compatible with this coding. What do you think?
  5. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I tried that but it won't move off the bottom. No matter which was I rotate it. Interestingly though when I check the voltage from the positive leg to the Vout I get exactly 1 volt in difference which is 4.08 volts.
    151,510Coins
    +11,041 / 56 / -2
    That seems to me to indicate a wiring or hardware problem. Check the wiring to the pot, including polarity, and if you have more that one swap them over, to try and pin down where the issue is.
  7. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Thank you Noorbeast, I have checked and double checked the wiring as per the diagram. I wonder if my sensor is faulty as you mentioned so I will try another one.
  8. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Update: I tried the second sensor and got no change. I am using a mega until my uno arrives but I think the structure should be similar and the pins universal. Having said that I switched to several different pins and still the same. Do you think it could be the difference in boards?
  9. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Correct me if I am wrong but doesn't the ground go to GND the positive go to +5v and the sensor connect to Vout and also be connected to A0 on the board.
    151,510Coins
    +11,041 / 56 / -2
    SMC3 is written for the Uno, so the Mega may be the issue.
  11. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I have an uno on the way and I kinda hope that's it but logic would state that with the mega simply being an extended uno that the syntax would be the same.
    151,510Coins
    +11,041 / 56 / -2
    They are not exactly the same.
  13. Tom1980
    Business Management
    Alabama, USA
    26Coins
    That must be the reason then. Thank you for the advice. I should have one in a few days and we will see.
  14. Gadget999
    12,007Coins
    doe the vout voltage go up and down when you turn the pot ?
  15. Tom1980
    Business Management
    Alabama, USA
    26Coins
    Hello and good morning, unfortunately the Voltage remains the same at all times. The Voltage going in is 5.08 and the Vout Voltage is exactly 4.08 in every direction the switch is turned even when turned completely around 360 degrees.
  16. Gadget999
    12,007Coins
    remove the signal wire from the pot and test again
  17. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I tried your suggestion but this is what happened. Any thoughts as to why. I am also very thankful for yours and everyone's help here.
  18. Gadget999
    12,007Coins
    Use a multimeter to measure the voltage on the output
  19. Tom1980
    Business Management
    Alabama, USA
    26Coins
    I have, the input voltage is 5.08 and the output voltage is 4.08. I am at a loss as to why I am losing one voltage. ON the other the voltage always stays at 4.08 no matter where I turn the Pot.
  20. Gadget999
    12,007Coins
    Remove the pot and benchtest it with no other wires just 5v and gnd
