Question Can someone help me to choose cheap motor?
Discussion in 'DIY Motion Simulator Projects' started by Lisu, Feb 6, 2022.
  1. Lisu
    Lisu New Member
    59Coins
    Hey, i want to change my wheel from dfgt to some direct drive, but when i look at prices of it i can't believe my eyes. I started searching, and found
    NEMA 34. Problem is in it that this sucks 6A and 9V. its really cheap in mine country but i don't think that i can find power supply and controller to get ffb, can someone help me pls?
  2. Lisu
    Lisu New Member
    59Coins
  3. Lisu
    Lisu New Member
    59Coins
  4. Gadget999
    12,001Coins
    its a stepper motor - not suitable for a DD wheel
    you need a DC motor or a servo motor
  5. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    438Coins
    yes you can find a cheap DC motor, and use a pulley and belt to get a smoother experience than logi wheel.
    I use my6812 motor, and it's have an ok torque
  6. Lisu
    Lisu New Member
    59Coins
    But how i can connect normal dc motor? do i need to use an encoder?
  7. Lisu
    Lisu New Member
    59Coins
    I dont want to use any pulley or something like that, I'd like to do a direct drive. I'll use it as a last resort.
  8. Lisu
    Lisu New Member
    59Coins
    so... is HF-KP73B Mitsubishi will be good?
  9. Gadget999
    12,001Coins
  10. Lisu
    Lisu New Member
    59Coins
    i can spend max 1500 PLN on the steering wheel ~ 330 eur. Its funny that Polish currency is so worthless.
    I found many step-servo motors hybrids, what is the difference between normal servo?
  11. itsumairu
    Psychologist
    Indonesia
    438Coins
    if you want to do a DD , its best use a servo motor, like @Gadget999 said.
    best luck to your project!
  12. Lisu
    Lisu New Member
    59Coins
    thanks, biggest problem is the budget (poland etc.) i found servo for 450 PLN, but i can't find driver to it and power supply
  13. Lisu
    Lisu New Member
    59Coins
    what do you thinking about hybrids? is it good to use step servo motor to direct drive?
  14. Gadget999
    12,001Coins
