Ultra Low Budget 2DOF Build. Home Stretch
Discussion in 'DIY Motion Simulator Projects' started by BD Jones, Feb 9, 2022.
Tags:
  1. BD Jones
    BD Jones New Member Gold Contributor
    20Coins
    I got laid off 9 months ago and money has been super tight. I've still been hellbent on building a DIY motion sim rig so I would save up a few dollars and buy one piece at a time. I know it looks terrible but this is the first iteration. I finally got the chair moving and know the next modifications I'm doing. I made a short video compiling the build process so far. In total right now the total cost of materials has been $272. I've spent about 15-20 hours fiddling with it.
    152,235Coins
    +11,066 / 56 / -2
    Creative recycling and careful purchases :thumbs
    The levers, as you have found, are way too long. With such limited inherent design leverage torque is really important, at a guess try about 40mm CTC on the levers.
    The other issue is that the universal joint looks too flimsy and hence unwanted lateral twist is evident. You could use a bigger universal joint, say off an old car tailshaft, or consider panhard rods between the upper and lower frames.
    What are the control boards, code and PSU specs being used?
  3. BD Jones
    20Coins
    Thank you for the awesome tips. I didn't think about a panhard bar. That would be a quick and dirty way to stabilize it.
    I'm using a 12v 20amp PSU from a dead Prusa Mendel 3D printer I built 10 years ago. I currently only have the free sim tools demo and I'm running SMC3 on the Arduino and driving the motors with ITB2's.
  4. BD Jones
    20Coins
    I did some research on panhard bars and came across the Watt's Linkage. So I went to Goodwill and found a folding golf bag caddy for $10, took it home and disassembled it and now the sim rig has a Watt's Linkage. The yaw due to lost motion is SO much better. Thanks again for the great idea.
    I also took your advice and drilled the holes in the lever to 40mm CTC.
    I made a quick update video showing the Watt's Linkage.
  5. BD Jones
    20Coins
    It turns out the handle to the golf caddy also makes a good hangar for the VR headset. I sat on the chair and moved the seat around. It has much more power now and seems ready for its first real test with a game. Of course there has to be a hiccup right? I plugged my vr headset into my laptop and it wasn't turning on. I disassembled the laptop to figure out what was wrong with it. It had previous water damage that I repaired so I figured it was corrosion. It's an Acer Helios 300 with a 1060 gpu. Turns out there's a broken pin on the only Type A USB 3.0 port. I found the part on Mouser and will fix it when it arrives.
    There is a USB C port on the laptop but I don't have any peripherals for it. I did order a USB C hub which should provide the speed needed for the VR headset, I'm just not sure if it will provide the power.
    152,235Coins
    +11,066 / 56 / -2
    The down side of hanging a VR HMD like that is that it is turned into a dust catcher, which is not good for the lens.
    You can make or buy a foam insert to protect the lens when not in use.
  7. BD Jones
    20Coins
    I did a caveman fix on the laptop usb port. I just had to test this thing out. I finally got to sit in it and drive. I can't believe it!
