AMC-AASD15A servo controller
Discussion in 'SimTools compatible interfaces' started by Thanos, Nov 6, 2019.
  1. Thanos
    Electronics Engineer
    2,907Coins
    I upgraded a bit more the power box by adding a meter. Everything still fit perfectly.
    See wiring information in case you are interested in making a similar one:
  2. Thanos
    2,907Coins
  3. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Hi @Thanos
    I bought your AMC -AASD15A motor controller last May and it no longer works. I turned it off as usual and when I opened it the next day, nothing. I checked the drivers and everything is normal, on the LCD screen I only have some kind of square that appears, what should I do?
  4. ericRacer
    Pilot
    Canada, Quebec
    952Coins
  5. Thanos
    2,907Coins
    It looks like it's in bootloader mode. Once goes on bootloader it remains until you load Firmware on it.
    The only reason I can think of being responsible, is an EMI spike that can cause a reset of the controller and undervoltage on the PC, that can trigger the bootloader... do you have the AMC-AASD15A hooked up directly on the PC motherboard USB port on the back?
    I'd recommend, disconnect all DB25 cables and load the firmware:
    https://www.simracingstudio.com/forum/motion-profiles-actuator/thanos-firmware-update-guide
    Also try to get one of these powered USB hub, so it won't happen again. Motherboard USB ports can be finicky with loads, and sometimes lower current limits to power save...
    Thanos
  6. ericRacer
    Pilot
    Canada, Quebec
    952Coins
    Yes it directly connected to the PC.
    I uploaded the new firmware last month .
    Surprinsingly i started it up today and it is working fine, i don't know what happened but it works ! maybe a spike like you said , i don't know.
    Thanks for the quick response, I will still consider buying a powered USB hub.
  7. Robdog
    Robdog Member
    Newcastle, Australia
    104Coins
    3DOF, JRK
    I have been trying to set up my new controller but cannot get it to talk to Simtools properly. When connected I get the message 'receiving motion data' but there isn't any movement, when I turn output testing off it shuts the game manager down.
    I currently have other motors connected using sabretooth drives, will this cause issues with the AMC software?
    Any help would be appreciated.
  8. Robdog
    Robdog Member
    104Coins
    3DOF, JRK
    It turns out I was connecting axis 5 on Simtools to servo 1 on the board, apparently axis 5 has to be connected to servo 5. All is working now but Simtools still shuts down when I turn off the motor test.
  9. Thanos
    2,907Coins
    Try using a line filter on the servo drive power, and perhaps try another USB cable, some cables are made way too cheap and with no shielding...
    Read here:
    https://luisblando.medium.com/how-i-solved-the-emi-problem-in-my-simrig-3ea6c0907609
  10. Thanos
    2,907Coins
  11. Thanos
    2,907Coins
  12. Thanos
    2,907Coins
  13. Thanos
    2,907Coins
    New Firmware release for AMC-AASD15A
    - Version 2.25 fix0
    • Added state machine for the LCD refresh to be performed only when needed.
    • Will display the state of the servos STANDBY or PARK immediately.
    • Improved the automated motion when not connected to the motion software.
    • Fixed a bug where a timer failed to restore affecting the colors of the LCD during online motion.
    The firmware locations have changed with each different folders for each chip version (1280 or 2560), along the firmware update utility with presets for each chip.
    https://github.com/tronicgr/AMC-AASD15A-Firmware/tree/master/Latest_firmware
  14. Thanos
    2,907Coins
  15. Thanos
    2,907Coins
  16. Historiker
    9,214Coins
    Well darn, now you have convinced me to update the firmware....that config tool looks great.
  17. S2.
    S2. New Member
    Finland
    86Coins
    How i config 20mm lead with 540mm stroke? Does config tool havve 20mm lead setting?
  18. Thanos
    2,907Coins
    I didn't include 20mm leadscrew as its not commonly used.
    But you can trick the controller into using one by selecting 10mm stroke with 270mm stroke value. Your 20mm leadscrew should extent to 520mm then just fine.
    Thanos
  19. Thanos
    2,907Coins
    Modern time Airworf !!
  20. Historiker
    9,214Coins
