Wiper motors 2 dof + traction loss motion sim
Discussion in 'DIY Motion Simulator Projects' started by Anthony atallah, Feb 11, 2022.
  1. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    106Coins
  2. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    20211214_191339.jpg 20211214_155441.jpg 20220114_142655.jpg 20220120_164313.jpg 20220209_132044.jpg 20220209_132126.jpg 20220209_132151.jpg 20211214_191339.jpg 20211214_191339.jpg 20211214_155441.jpg 20220114_142655.jpg 20220120_164313.jpg 20220209_132044.jpg 20220209_132126.jpg 20220209_132151.jpg
  3. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    I even built a diy "racing bucket seat", kind off o_O
    Using metal sheets from a washing machine for the back, and the chassis of an lcd tv for the bottom :grin
    151,528Coins
    +11,042 / 56 / -2
    Nice work :thumbs
    Something to keep in mind, if you have not done so already you will need to check and if necessary adjust the balance of the rig with yourself in it, plus with all peripherals attached: https://www.xsimulator.net/communit...-of-gravity-to-balance-a-motion-simulator.55/
    The rig has a fair amount of mass, where do you plan mounting the motors, near the feet to maximise inherent design leverage or somewhere else?
  5. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,407Coins
    I agree with Mr. Noorbeast.. the balance of the rig (with wheel, pedals, and YOU sitting it it has to be pretty close to the center of mass. Also I had to mount my motors way back and use pushrods to the top of the seat to use the most potential power of the motors. Had I mounted them real low under the seat, they might not have had enough power to move the full frame like yours.. Keep building it my friend! DMAX
  6. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Yes I did a balance check with me in it and wood logs to simulate the peripherals and steering kit weight. As shown below in the first image, but I'm working alone.
    I did also all the wiring and a startup on smc3.
    151,528Coins
    +11,042 / 56 / -2
    Great progress :thumbs
    How have the motors coped with initial tests?
  8. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Today I'll set the parameters of smc3, I felt that one of the motor was a bit slower on reverse.
    But they look fast and powerful without a major load yet.
  9. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Reinforced the u joint and motor holders.
    And did more testing and tweaking.
    I'll try to upload a video.
  10. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Here's the YouTube link of the first tests.
    Please consider subscribing if you're interested in my other projects also.
  11. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Looking good this is very close to what I'm trying to achieve very nearly there.
  12. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Feel free to ask anything.
  13. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    What motors are you using? As I'm already thinking I need more power I have 12v wiper motors
  14. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Using 70/80 mercedes 12v wipers.
    I was skeptical, but I spent more than 2 hours playing LFS without too much heat.
    And I could crank it a bit more.
    Also a 100ah battery that couldn't crank the pickup anymore.
  15. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    I got myself a 12v 350w PSU hope it will cope with 3 12v motors.
  16. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Is it a desktop power supply??
    I think you will mostly max it.
    I will try to use 10amps fuse for each one, if they break, we will know peak current. I'm using 20amps fuses without problems.
  17. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    This is my current steering and pedal setup. It's working good but not enough. So I started gathering resources for a proper diy ffb.
  18. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    I would recommend to use leonardo boards for these kits because it's easier and way more versatile.
  19. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
    Today i got a used but immaculate lenovo VR headet and joystick, and managed to get it working with Live For Speed.
    NO WORD COULD DESCRIBE THE EXPERIENCE!
  20. Anthony atallah
    Mechanical Engineer
    Lebanon
    106Coins
