Showroom 2/3 DOF Traction loss wiper motor DIY Motion Sim
Discussion in 'DIY Motion Simulator Projects' started by Martin Dixon, Feb 11, 2022.
  1. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    So, I decided to build my own motion platform after watching D MAX on you tube so all credit goes to him for the inspiration on starting this build.
    I started with an idea that I wanted to use it for my sim racing and flight sim before I started, I decided that I was going to begin simple and go for a 2 DOF and upgrade to a 3 DOF later.
    After doing a lot of research and pricing up I decided to go with Arduino and H Bridges 43A using 12V wiper motors as I felt this was the cheapest way to go and there was plenty of info and tutorials on the forum.
    Just to be clear this build could be even cheaper if you know where to go for materials as I just bought most of mine from amazon and B&Q for ease. Also, if you see anything I could improve on just let me know.
    First step for me was ordering a few parts which were.
    • 43A H bridges
    • Arduino Uno R3
    • Uno Shields (optional for ease)
    • Stand offs
    • Telephone cable
    • 12v Power supply
    • 10k Potentiometers
    • 2/3 12V wiper motors
    The schematic I followed was from the Xsimulator forum by RufusDufus (see picture and link below) and seems to work but not fully tested it yet.
    This is how it turned out for me without the motors and power supply attached. I did test it with SMC3 and it seemed to read just fine.
    started my frame by using a wheel stand that I had bought with my wheel
    and added some box section of about 1.2m in length fixing it together with M6 Bolts and nuts.
    I then made a base using the same materials and added some wheels as I wanted to be able to have traction loss later on so incorporated it into the build but not going to use it till 2DOF is working.
    I then scoured the internet to find myself a UV joint fit for my project and managed to find a MX5 prop shaft which I ended up cutting down and adding brackets.
    I then mounted it to the bottom frame using angled steel. upload_2022-2-11_20-44-55.jpeg upload_2022-2-11_20-44-55.jpeg
    I then put on the top frame and found myself a racing seat and harness on the market place and made myself a makeshift seat bracket to be able to mount my seat.
    My next step is to mount up the electrics and then I want to test just having an issue with the motors as I need to isolate the grounds due to my rig being all metal so once I figure that out, I will come back and update.
    So did a bit more on the rig and corrected some of the miss takes managed to get all the electrical stuff working with SMC3 how it should just need a few mor credits to but a download pack and plugins.
    Things I have notice that need more attention:
    • Motor mount's need to be redone stronger
    • Need to figure out how to strengthen the UV joint bottom mount as it flex's a little bit.
    • Make stronger rods
    So to make the UVJ mount I decided to try a sleeve and got my mate welding it to a steel plate so that the UVJ can slide inside have done it so it is a super tight fit see how we get on EY.
    Quick update the above worked and is hold me fine.
    I have also now strengthend my rods and motor mounts and everything is working as it should, can't belive how much immersion it creates
    Added my seat harness to on a spring to simulate tension under braking.
    Next is a couple of shakers and I think it's done as a working model and then it's time to tidy it up electric housing etc maybe even do the 3rd axis now as the driver and pot is already done.
  2. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    Hello there!
    just curious, have you test it sitting on your rig? I think the material plate for the base is too thin, and I can see its bending. You can use aluminum extrusion like I did, and size 3030 is enough to accommodate the load of my weight.
    Cheers!
  3. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Yes mate it holds me but I am gonna upgrade it cause I'm not happy with it with thinker rails and plate
  4. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    107Coins
    The pivot of the u-joint is down near ground??
  5. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Is that the wrong way to do it and if so why ?
    153,986Coins
    +11,161 / 57 / -2
  7. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Exactly as Mr. Noorbeast said.
    Also try to add 2 bolts instead of for the frame, or X brace diagonally for more rigidity.
  8. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    But I think it's a bit weak frame, as there's flexing in the middle alteady. So maybe double the sides steel profiles on top of each other.
  9. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
  10. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Sorry I'm not understanding where you want me to put extra bolts
  11. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    I have put an extra set of wheels in the middle of the frame to support the frame to prevent the flex.
  12. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
  13. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Red arrows where it's better to add a second bolt.
    Yellow is an example for the diagonal bracing.
  14. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    If you try turning the big driven wheel, does the frame rotate as you would expect it?
    I guess all those swivel wheels will affect the motion badly.
  15. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Yes it seems too but I was considering anchoring the front on a single pivot.
  16. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Don't think it's enough.
    You won't be able to feel small movement.
  17. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    What do you suggest then, oh and thank you for pointing out the UV joint as that would of caused me a right nightmare later am sorting that out today.
    I'm open to ideas as this is a proto type to learn from i will most likely rebuild once it works and improve on all these points you guys keep throwing at me.
    every day is a school day LOL.
  18. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    What kind of tools and hardwares you have in your reach?
  19. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    hand mostly grinder drill etc
  20. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
