Question Arduino Controller?
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Rodeo5150, Feb 18, 2022.
  1. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    Hi all. Ok so Im at the stage where Ive got it mocked up enough to maybe start testing the design. I know I should test a little less built but I just had to see it in the air. Ivew been in the garage for a week straight welding my butt off and just had to see it lol. Im gonna be doling 6dof with 2 R3 uno's and 6 Ibt-2's with (temporary) wipewr moters till I can find some dc motors and worm gear reducers under $50 each, thinking maybe 6 12v 350w psu's (again that wont break the bank).
    Anyway does anyone have a suggestion on Arduino controllers like the SMC3 that I should use?
    thank you
    Heres my rig if anyones interested 20220217_230825.jpg 20220217_230810.jpg 20220217_234008.jpg 20220217_234108.jpg 20220217_234253.jpg
    152,553Coins
    +11,086 / 56 / -2
    Why don't you stick with SMC3, as it has variants supporting a wide range of controllers, plus a handy visual configuration app?
  3. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    ok I will I jjust couldnt find it but You gave it to me so Im gonna do that.. THANK YOU for all your help @noorbeast. Your the only one really even trying to help me
  4. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Im doing this all on my own with absolutly zero prior knowledge of what Im doing and never used Arduino before
    152,553Coins
    +11,086 / 56 / -2
    In that case SMC3 is likely your best bet, as it has SMC3 Utils, which provides a simple visual driven configuration app.
  6. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Perfect.. ya Ive uploaded it on my arduinos and now im in the middle of wiring and realized I havent nailed down any power supplies or hall effect pots yet.. I found some simple 10k pots around the house but having a hard time finding any psu or 12v batts to test it out lol I really don't expect these motors to do much though to tell you the truth I don't think they're strong enough for as heavy as I've made it. Its not extremely heavy but it's heavy enough that I think these Motors aren't suitable plus they have plastic gears in them I just found out
  7. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    107Coins
    Hello nice build so far :thumbs
    If you find out that the motors are weak a bit, try decreasing their crank arm maybe it'll help.
  8. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    You mean shorten them a bit? Do you think they are a little long? I didnt know how long to make them
    152,553Coins
    +11,086 / 56 / -2
    At a guess try about 40mm from the shaft to a hole, and see how that goes.
  10. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Ok cook thank you
  11. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Yes exactly.
    Try addind 2 holes for each arm and start by the minimum length. If it feels good try the next one.
  12. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Cool thank you.. i need all the rules of thumb I can get
