Showroom 2/3 DOF Traction loss wiper motor DIY Motion Sim
Discussion in 'DIY Motion Simulator Projects' started by Martin Dixon, Feb 11, 2022.
  1. Anthony atallah
    Anthony atallah Member
    Mechanical Engineer
    Lebanon
    107Coins
    To be honest, I don't think it'll hold.
    Even the motor mounts are weak.
    I've cut some corners and I regret it, because it will experience continuous vibrations and shaking.
  2. Anthony atallah
    Mechanical Engineer
    Lebanon
    107Coins
    Look below how how I reinforced the u joint in red, and yellow for the motor mounts and still there's some flex
  3. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    I could access one but not competent in using it and my mounts are weak but I will address this.
  4. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Probably the more expensive way to do it but I'm testing and adjusting.
  5. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Did a bit of an up date on the main thread.
  6. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Just received my free DIY licence thank you so much :cheers
  7. Billel
    Billel Member
    195Coins
    have you tried the rig yet ? i want to know if those wiper motors are strong enough to move the rig in all 3 rotation axis
  8. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    Yes didn't do the 3rd axis in the end but they moved me easy for pitch and roll and I'm 90kg
  9. Billel
    Billel Member
    195Coins
    did you build a seat mover or a do they move the whole platform (including steering wheel and pedals) ?
    153,697Coins
  11. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    It moved the whole thing mate seat pedals and wheel with me and vr headset
  12. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
  13. Billel
    Billel Member
    195Coins
    I you have a video of the 1st rig in action, it would be great if you could share.
  14. Martin Dixon
    Martin Dixon Member
    Sgt HM FORCES
    Devizes, Wiltshire
    26Coins
    I do but it's to large to upload sorry could send it via other means inbox me if you want it
  15. Billel
    Billel Member
    195Coins
    PM sent
