Showroom IL2 Sim on 2 Dof
Discussion in 'DIY Motion Simulator Projects' started by xmcnodx, Nov 30, 2021.
  1. xmcnodx
    xmcnodx IL2 Sim with 2Dof
    Schmelzer
    Zirndorf Deutschland
    94Coins
    How to patch it.
    As described, I simply dragged the pulings over with the mouse
    153,764Coins
    +11,149 / 57 / -2
  3. xmcnodx
    Schmelzer
    94Coins
    Always get that it does not go to patch
  4. xmcnodx
    Schmelzer
    94Coins
    I keep losing the connection with GameEngine and then have to disconnect and reconnect the PC and sim.
    153,764Coins
    +11,149 / 57 / -2
    The directory path is not correct, it needs to be where IL-2 is located.
    Are the motors moving out of range/tripping PSU or is it a sound notification indicating a USB disconnect?
  6. xmcnodx
    Schmelzer
    94Coins
  7. xmcnodx
    Schmelzer
    94Coins
    have managed to patch it but no signals come up
  8. xmcnodx
    Schmelzer
    94Coins
  9. xmcnodx
    Schmelzer
    94Coins
    the motors always lose the centre position, the podi must be readjusted again and again and the motors always burn
    153,764Coins
    +11,149 / 57 / -2
    This shows that data s not flowing to the Tuning center, suggesting the patch path is not correct or external interference by the likes of Anti-virus or firewall software.
    As an aside, intensity levels should be at 100% except in circumstance where there is vulnerable hardware, such as SCN actuators.
  11. xmcnodx
    Schmelzer
    94Coins
    Help yesterday reinstalled Win10 because I got Networks error message from the beginning, now after the new installation plus Simtools the message is back, what else can I do.
    153,764Coins
    +11,149 / 57 / -2
  13. xmcnodx
    Schmelzer
    94Coins
    I have re-installed the network, but unfortunately the same error message still appears.
    153,764Coins
    +11,149 / 57 / -2
    Hit the Details button on the error message to show the full details, copy and paste those here and @yobuddy could have a look.
  15. xmcnodx
    Schmelzer
    94Coins
    System.ComponentModel.Win32Exception (0x80004005): Only part of the ReadProcessMemory or WriteProcessMemory request was completed
    at System.Diagnostics.NtProcessManager.GetModuleInfos(Int32 processId, Boolean firstModuleOnly)
    at System.Diagnostics.ProcessManager.GetModuleInfos(Int32 processId)
    at System.Diagnostics.Process.get_Modules()
    at SimTools_GameManager.frm_GameManager.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc (Message & m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4470.0 built by: NET48REL1LAST_C
    CodeBase: file: /// C: /Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Assembly Version: 0.2.5.1
    Win32 version: 0.2.5.1
    CodeBase: file:///I:/Simulator%20Ordner/SimTools2/SimTools/SimTools/SimTools_GameManager.exe
    fZMkmPzPHuCqHgqhDnkBggdEJqAS
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 version: 1.0.0.0
    CodeBase: file:///I:/Simulator%20Ordner/SimTools2/SimTools/SimTools/Game_PluginAPI.DLL
    System.Management
    Win32 Version: 4.8.4435.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    AssettoCorsaCompetizione_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 version: 2.0.0.0
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/AssettoCorsaCompetizione_GamePlugin.dll
    DCS_Exp_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/DCSX_Exp_GamePlugin.dll
    DCS_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/DCS_GamePlugin.dll
    Dirt3_GamePlugin
    Assembly Version: 2.0.0.1
    Win32 version: 2.0.0.1
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/Dirt3_GamePlugin.dll
    EliteDangerous64_GamePlugin
    Assembly Version: 2.0.0.2
    Win32 version: 2.0.0.2
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/EliteDangerous64_GamePlugin.dll
    EpicRollerCoasters_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/EpicRollerCoasters_GamePlugin.dll
    FlatOut2_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/FlatOut2_GamePlugin.dll
    ForzaHorizon4_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/ForzaHorizon4_GamePlugin.dll
    HyperStorm_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/HyperStorm_GamePlugin.dll
    IL2CloD_Plugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/IL2CloD_GamePlugin.dll
    IL2Sturmovik_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/IL2Sturmovik_GamePlugin.dll
    The_2BoS_GamePlugin
    Assembly Version: 2.0.0.5
    Win32 version: 2.0.0.5
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/Il_2BoS_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.1.0.0
    Win32 version: 2.1.0.0
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    NFSMostWanted2005_GamePlugin
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/NFSMostWanted2005_GamePlugin.dll
    WarThunder_GamePlugin
    Assembly Version: 2.3.1.1
    Win32 version: 2.3.1.1
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/WarThunder_GamePlugin.dll
    XPlane_GamePlugin
    Assembly Version: 2.0.2.0
    Win32 version: 2.0.2.0
    CodeBase: file:///C:/Users/xmcno/AppData/Local/SimTools/GamePlugins/XPlane_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  16. noorbeast
    153,764Coins
    +11,149 / 57 / -2
  17. xmcnodx
    Schmelzer
    94Coins
    Should I send it to @yobuddy the error message?
    as it is not always the case that the programme translates English into German
  18. noorbeast
    153,764Coins
    +11,149 / 57 / -2
    Just wait until @yobuddy has a chance to have a look and comment.
  19. xmcnodx
    Schmelzer
    94Coins
  20. yobuddy
    51,527Coins
    This is a new one for me, so I did some searching on google, and it seems to be somewhat common.
    In all of the fixes presented at various sites and even some YouTube videos, it seems it may be a problem with either permissions, hdd errors, or a bad stick of memory.
    Let's start with Antivirus thou, what are you using?
    Maybe install avg free and give it another try.
    Let me know what you find, and we can go from there.
    Take care,
