Tutorial Arduino RevBurner driving a tachometer.
Discussion in 'DIY peripherals' started by jamesdio, Oct 11, 2014.
  1. cazsan
    cazsan Member
    Programmer
    444Coins
    I finally got it working removing 12V zener diode...
    I don't know why but it seems to be embedded in my aftermarker tachometer gauge
  2. peel
    peel New Member
    mechanic of printing machines
    Martin Slowakei
    143Coins
    3DOF, Arduino
    hello experts, please help. If I connect the tachometer according to the original instructions, it does not work. However, if I connect the GND from the Arduino to the emitter, the tachometer works correctly. Why is that so?
    Tacho: https://a.aliexpress.com/_mLG2mnK
  3. Etcho
    Etcho New Member
    17Coins
    @peel , you just saved my life. I've been trying everything I could try, replaced all the components, with no luck. I just did the ground trick you suggested and now it works.
  4. AVSTech
    AVSTech New Member
    16Coins
    Hey, all!
    I tried using the provided circuit for my tachometer (Auto Gauge 8000RPM) nothing worked. Then I checked my tachometer by quick taps to +12V with the green signal wire - the hand moved. So I realized that my tachometer is switched to a positive signal. Accordingly, I had to use a PNP transistor to work, so I chose 2N3906 - as I had it in stock.
    The total circuit looks as follows:
    Best Regards
  5. Stefan Koopmans
    Stefan Koopmans New Member
    16Coins
    @AVSTech, After a week of fiddling around without a multimeter I had no way to understand why my Tacho was not working properly. Your explanation got me on the right path though. I could also get the needle to move by tapping the green wire to 12V. I searched around my old pile of electronics boards to find a suitable PNP transistor and used your diagram as a reference. It also happens to be a very small TO-92 transistor, even weaker than yours. I also used a very small glass zener diode and I don't even know it's specs, can't read it. Anyway it finally works! Thanks a lot! Signed up here specifically to make this post :)
  6. Mezba
    Mezba New Member
    2Coins
    brother can i use Arduino Nano
    brother how could i Use Arduino Nano R3 Please let me know.one more think can i use Arduino Nano Dircet to ta Tachometer,I mean can i ignore the below components and direct give connection to the Arduino Uno?
    1. arduino - 1 pcs
    2. TIP-120 Darlington Transistor - 1 pcs
    3. 2.2Kohm resistor - 1 pcs
    4. wires
    5. 12V dioide - 1 pcs
    6. 12V Power supply - 1 pcs
  7. Mezba
    Mezba New Member
    2Coins
    brother how could i Use Arduino UNO R3 Please let me know. One more thing: can I use Arduino UNO directly as a tachometer? I mean, can I ignore the below components and directly connect to the Arduino Uno?
    1. arduino - 1 pcs
    4. wires
