FlyPT Mover 3.5.3
  1. Michail
    Michail Member Gold Contributor
    723Coins
    Hello I would like to to try flypt mover for virtual motion compensation, can I use the simtools gameplugin?
    Or need more? In the section sources, there are my games, PCARS2, AC and AMS2 do I need extra plugin for?
    Do I need extra subscription like SRS? Do I need extra hardware for "virtual" controller to get right with motion compensation? Sorry I am completly new. And I learn day over day
    will it work in 2dof plus traction loss or only full steward 6dof supported?
  2. Michail
    723Coins
    Ok just try your tutorial for dirt rally 2.0 in YouTube to setup the rig dofreality h3 which is similar to my diy and no rig 2dof plus traction loss found to choose.
    I struggle a lot and hope, that I can use this one to make it better.
    i want to make virtual tracker as well for ovmc. But first I have to make a good profile for the motion. Unfortunately there are no tutorial on youtube with 2dof.. only 6dof
    I love the suspension and special the rpm vibrations.
  3. Mauricio
    Mauricio Member Gold Contributor
    75Coins
    Hi, Im using Cessna or Bonanza. Thank you so much for your help.
  4. J-1775
    J-1775 Aviator
    1,582Coins
    Just in case you haven't noticed yet: with current version of FlyPT Mover you have access to the online repository. There's at leat one DR2 file by Zen, haven't checked for how many DoF it is. But you may learn a lot by looking into other 2 DoF profiles.
  5. imagebuff
    imagebuff New Member
    Tomball TX
    269Coins
    Trying to get Pose from RPM to work. The only method I see to modify rig motion intensity is Rotational and Translational vibration. I set both to their absolute minimums of .1 and they are still crazy intense and unusable. I was just moving the RPM slider to test and don't dare go past the first click. Is this pose working? Anyone successfully using it?
  6. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    Can’t you go below 1 ?
  7. Michail
    723Coins
    Later I will post my settings for RPM which I realy fell in love... AndI have pose from motion problems... But this is another part. So I switch back to simtools.
  8. imagebuff
    Tomball TX
    269Coins
    I used 0.1 for each setting which is the minimum setting and it is far too violent. It seems "Rotational vibration" is the hyper sensitive one. Using 3.5.3.
  9. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    I have a beta 3.6 and can go lower:
  10. Michail
    723Coins
    As I mentioned before, here my settings for a 2dof plus traction loss system with CTC lever 67mm. As Rig I use in flmoover dofreality H3, which is the most suitable for my case.
  11. imagebuff
    Tomball TX
    269Coins
    Looks like the change I need. Thanks for letting me know.
  12. Mat_Menzies
    Mat_Menzies New Member
    92Coins
    Hi All, I was just catching up on the last few pages of this thread and noticed some questions and comments on the Dirt Sprint cars in iRacing and no suspension telemetry. This may be correct because when I was around these cars they didn't have suspension. The rear transaxle was fixed in the chassis and the front axle would pivot at the centre point. They did have shock absorbers on the front axle to aid in transition of uneven surfaces, but no spring forces acting in either direction. Pretty much just like a tractor!
    I don't know if more modern car designs have rear suspension, nor do I know if iRacing dirt sprint cars model rear suspension, but it may be the reason there is no suspension telemetry from these cars.
  13. Trigen
    Trigen Active Member
    2,890Coins
    Issue with Thanos and directs. G seat. Mover 3.5.3
    Setting a home position in directs will instantly move the axis there when connecting but then slowly go back to 0 position. It does the same thing when you disconnect
    I can set a bit range -3 to 200 to make it stay in that position but that is also a instant move.
    I cant use Thanos standby position cause i am using it for G seat Rotary and Lincear 200mm Actuators.
  14. Historiker
    9,208Coins
    I fell down the rabbit hole again, love your Mover software @pmvcda
    Just how many modules can I stuff into Mover for ETS2? We will see, MUAHHAHHAHHA!
    By the way, has anyone gotten more than two channels from an audio source for transducers? My Sound Blaster X-Fi is configured for Quadraphonic but Mover only see's two channels. Works as four for other vibe software. Not a big deal but it would be nice to have all four bass shakers massaging my...er...ego :D
  15. pmvcda
    15,478Coins
    Been hidden for some time, sorry.
    There's a bug in the transducer module.
    Found that some audio devices (most) are not showing all the channels.
    I have it solved for the next build.
    But it will take some extra time for release, I had to rebuild most of the code to get rid of some nasty bugs.
    There's going to be many updates, new features and a cleanup of some modules
    • Like Like x 10
  16. pmvcda
    15,478Coins
    Ok, will take a look.
    I have something new in the filters for the next release.
    Main reason for the delay...
    Think it's going to be good for this type of systems.
    - Conditional filters (IF ...)
    - We can use any of the source values in the filters by using keys
    Something like IF(LAT_A;>50;0;LAT_A)
    That 1 is > for now, not at release
    VALUE is the value as we have in current version, but we can uses for example LAT_A (lateral acceleration) or any other value in the numeric fields
  17. Avee
    Avee Virtual Pilot
    1,167Coins
    Is that limited to the same source? Reason I am asking is, I would like to make a filter that only works when ground mode is sensed by the sim, which takes the current speed and uses a direct joystick (=different source) input for gain.
    My goal is not to wait for the simulator to calculate G force, but to initiate a motion cue in a certain situation as close as possible to control input. Steering on the ground in an aircraft or car is almost hard wired to the lateral Gs, and I want an effect without any delay from the sim.
  18. pmvcda
    15,478Coins
    No it will be for all sources
    Something like:
    S1.LAT_A
    This is for source with key S1
    So if you add a joystick source, you can use the Lateral acceleration for that source.
    You can make things like: ADD(S1.LAT_A;S2.LAT_A)
    The only problem, I'm looking at now, is the use of those keys in filters we have on the sources.
    They are affected by the order the sources are calculated. So the value you get can be from previous calculation loop or already the new one on the current loop. Hope you understand what I mean.
    Those keys can be used in the outputs also.
  19. Avee
    Avee Virtual Pilot
    1,167Coins
    That's great! I think for my purposes, uncertainty about the sampling of the input data is not of great influence. I will have on ground braking and steering effects derived from the controls, and in the air I will take the sim calculated data. Since traction loss is not something commonly simulated in flying, I think that will work sufficiently well.
  20. Michail
    723Coins
    I am wondering if there is an solution, that I will post later in this thread the tuning setup and axis settings of ams2/pcars2 to help me here someone for translate in in mover, so that i can use the virtual tracker for motion compensation.
    Do we have to setup the output for the virtual tracker as well? it don't seam right to me. I get motion sickness. Hoe the tracker knows, how far the motions are?
