2DOF seat mover project windshield wiper arudino IBT2
Discussion in 'DIY Motion Simulator Projects' started by Halloween2go, Aug 22, 2021.
  1. Halloween2go
    Halloween2go Active Member Gold Contributor
    1,395Coins
    I have not been able to find a real good video on how to convert a static rig into a 2DOF sim. So I made one that covers a lot of the topic. I know you guys are experts on this, so I figured I would share out the the video. This is part one of two, which covers Arduino, IBT2, hall effect pots, SMC3 and isolating ground on Windshield wiper motors. The content is pretty solid. - The follow up video will cover modding a static sim rig for motion and simtools setup. Thanks for looking.. DMAX motion sim channel on youtube.
    • Friendly Friendly x 2
    153,697Coins
  3. Halloween2go
    1,395Coins
    video #2.. Sim Rig Frame// mating the U-joint and keeping it within the sim rig footprint
  4. Halloween2go
    1,395Coins
    Part 3.. now that the seat is mounted .. Motor mounts and clearances
  5. Halloween2go
    1,395Coins
    Just finished up part 4 on my DIY motion sim series - Turn your static sim rig into a Seat Mover. Take a look if you have time.. Thanks.. Here is the YT link..
  6. TERENCE Teed
    TERENCE Teed New Member
    91Coins
  7. TERENCE Teed
    91Coins
    Alright big Man. Found you here. Good. Welders here. Got motors, arduino and project boards, IBT2s are ordered, 2 of the 4I need anyway. Power unit will order next month. Great. Think I may have cocked up buying the 24v motors though. The IBT 2s will run 12 v.
  8. Halloween2go
    1,395Coins
    Upgraded to bigger motors .. Most stuff in description of video .. 24 volt converter, Jazzy wheelchair motors Video #2 on building your own motion simulator for Assetto Corsa.. Take a look if you have time DMAX
  9. Halloween2go
    1,395Coins
    The IBT's apparently can run 24 volts.. that's what I'm going to do here.. If the smoke comes out, we will know they Lied on the specs.. but I think they are good up to 36 volts according to their data sheet.. Dave
  10. seuszok
    Poland
    465Coins
    I use ibt on 24v, 2x on one motor and runing fine.
    Begining when I run on one - hot a lot , turn off by inside safety or burn (6 of them go for scrap in my case)
    They runing wheelhair motors - some 200-300w 24v, power suply stabilized 24v siemens
  11. Halloween2go
    1,395Coins
    It's been a couple weeks.. But I made some headway with the AMP test.. putting an ATV brake on the 2DOF Bigger motor build.. check it if you have time..
  12. Halloween2go
    1,395Coins
    Hi, thanks.. This is my first time using Converters. They are supposed to be good to 25 amps.. In my latest video I was actually able to 'test' the stall amps for one of the motors. Pretty close to 20 amps sometimes. But further testing is needed once I get both motors 'working' with my weight in the seat. Check out the video if you have time.. I put an ATV brake on one of the motors to get a good 'stall amp' reading.. DMAX
  13. seuszok
    Poland
    465Coins
    Thx for Ukraine apel :thumbs
    I can only share knowlage with my build so You can take a look on my build. I try to describe all thing what want to stop my progres or could help someone.
    Yestarday electrical shemat: (I realy recomend two ibt on channel)
  14. Halloween2go
    1,395Coins
    Nice .. I did take some looks at this.. Full frame rig.. The action looks great! Nice work.. I want to try and make the upper frame out of something lighter than steel on my 3dof RIG mod.. It works fantastic but If the motion frame (upper frame) was lighter, I'm sure it would respond accordingly Power to weigh.. Thanks DMAX
  15. Halloween2go
    1,395Coins
    OK.. So here is a quick video on wiring up the POWER wires from the converters to the IBT and the IBT to the motors and more.. Take a look if you have time.. DMAX
  16. 0v3rkill
    0v3rkill Member
    Programmer
    Netherlands
    - 269Coins
    hey Dave you the one that inspired me to build my rig, remember the 360 instead of 180 degrees hall sensor?
  17. Halloween2go
    1,395Coins
    I imagine that the 360 may need some modification to the arduino code readings A0 A1, A2?
  18. 0v3rkill
    0v3rkill Member
    Programmer
    Netherlands
    - 269Coins
