6dof project with low cost wiper motors and 24V IBT-2
Discussion in 'DIY Motion Simulator Projects' started by SteULM, Jan 12, 2022.
  1. SteULM
    SteULM Active Member
    601Coins
    Thanks seuszok. The power supplies are connected to ground but not the arduinos ... I don't use cards with ch340 but atmega328P
  2. SteULM
    601Coins
    I also have to connect the negative pole of the arduino to ground ... ??
  3. seuszok
    Poland
    465Coins
    Yes but atmega have data transfer on other chip
    I was change arduinos from ch340 to 16u2
    Also I connect ground line from power suplies (3 x 24v )and arduinos grounds like on picture
    Its take me a litle bit time but should be clear
  4. SteULM
    601Coins
    Yes, I have the 3 arduinos with 16u2 chips ...
    Now I go to the laboratory and connect the negatives of the drivers with the arduinos ...
    Then I write the results in the meantime, thanks you are very kind.
  5. SteULM
    601Coins
    Great seuszok !!!
    Problem solved, as you made me do, putting the negatives of the bridges and the arduinos worked perfectly, now it does not disconnect anymore !!! Thanks for the time and patience you have dedicated to me (noorbeast and seuszok) to support me, you are great !!
  6. SteULM
    601Coins
    Here is a video with the rig finally working at 100%.
    Thanks again to the friends who supported and endured me ... :grin:cheers
    • Winner Winner x 3
  7. SteULM
    601Coins
    Fans mounted to cool the engines and create some atmosphere...:grin
  8. itsumairu
    itsumairu Active Member
    Psychologist
    Indonesia
    440Coins
    its looks like a space craft lol, good job!
  9. Keith
    Keith Active Member
    Electrician
    Canada, Saskatchewan
    154Coins
    Lol. Actually looks pretty neat!
  10. SteULM
    601Coins
    Dirt Rally 2 is too good and so, always with the aim of keeping costs as low as possible, I inserted sequential shift and handbrake to the rig. Rustic but functional ....
  11. SteULM
    601Coins
    A particular.....
  12. SteULM
    601Coins
    And in order not to miss anything, I finished the tool with TM1638 and Game Dash
  13. SteULM
    601Coins
    Yesterday my cousin brought me the other two 43" monitors, which together with the first 47" I intend to mount with an iron structure on the rig
  14. SteULM
    601Coins
    I was thinking of a structure like this, considering that the 47 "monitor weighs 12kg and the two 43" 9kg. Will a 40x30mm 3mm thick L-shaped iron section be able to withstand these weights?
  15. SteULM
    601Coins
    I changed my mind compared to the structure I had designed, making it lighter to the eye ...
  16. SteULM
    601Coins
    Here is the complete structure to be painted, tomorrow I try to mount it with the monitors and if everything goes, I paint it.
  17. SteULM
    601Coins
    I didn't want to wait for tomorrow to see it assembled .... :grin
    I have to make a couple of changes but everything looks ok
  18. SteULM
    601Coins
    Ok painting finished and structure assembled ....
    Huge
  19. SteULM
    601Coins
    Everything connected to the pc, now nvidia setup
  20. SteULM
    601Coins
    First test with triple monitors, a show ....
