Showroom Ejection seat handle
Discussion in 'DIY Motion Simulator Projects' started by Turbo Tim, Jan 17, 2022.
  1. Turbo Tim
    Turbo Tim Member
    159Coins
    Hi guys
    Built this a while back and thought I would share it. While flying in DCS in vr it was impossible to find ctrl and e on the keyboard to eject before bursting into flames. I made an ejection seat handle. Basically a micro switch, arduino board which replicates ctrl and e being pressed 3 times. A spring and the handle made out of a piece of stud bar and garden hose with black tape around it. Its a bit of fun and works a treat.
    • Creative Creative x 3
  2. hcee2022
    hcee2022 Member
    Finland
    196Coins
    I've noticed the same difficulty while flying in VR, and built something similar for my motion integrated g-seat.
    Btw, do you get force input from Simtools when punching out? There's currently no feedback if I have to suddenly leave my F-14 (the handle works great though)
    153,824Coins
    +11,150 / 57 / -2
    A force has to be incorporated into a plugin, does the ejection actually equate to heave in the game, I am presuming in DCS?
  4. hcee2022
    hcee2022 Member
    Finland
    196Coins
    I have to check; this can probably be captured in Tuning center values, if I reset heave to zero and fly level (while motors turned off) before ejecting.
    I'm using the "Digital Combat Simulator (DCS) - Experimental plug-in v0.10" for Simtools.
    153,824Coins
    +11,150 / 57 / -2
    Try to auto capture DCS Tuning Center during eject, or alternatively a small value like 0.5 to see if you can feel it, rather than zero.
  6. 0v3rkill
    0v3rkill Member
    Programmer
    Netherlands
    - 269Coins
    would be cool if you could release presured air under your seat as soon as you pull the cord.
    give you a bit of a realism feel to it :D
  7. hcee2022
    hcee2022 Member
    Finland
    196Coins
    I finally had the chance to test this, and unfortunately the game is sending the telemetry data for the plane, not for the pilot :D
    That means, while parachuting down, I can feel the kaboom when the plane hits the ground. Have to study the export options more to see if it's possible to change that..
