My 6DOF AC Motor Project
Discussion in 'DIY Motion Simulator Projects' started by wyh0607b, Jul 16, 2019.
  1. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    Hello everyone. I've been on this project for some time. Now, I want to experience with the process and to share.
    I used to watch video on analog movement on the Internet. I feel very interesting. Because I was in the basement of my house empty, I would like to make a car racing simulator came to play. My concern is often the site:
    https: //www.xsimulator.net
    http: //motionsim.blogspot.com
    where I learned a lot, buy a lot of equipment, so I started my work. Here is my share.
    153,740Coins
  3. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    P50701-191217.jpg P50619-012006.jpg P50706-005746.jpg P50704-012917.jpg P50713-001956.jpg P50715-235457.jpg P50716-004525.jpg P50720-030544.jpg P50724-024023.jpg P50727-005338.jpg P50730-194838.jpg P50701-191217.jpg
  4. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    The work is not finished yet. I will continue to update it.
  5. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Good job, the electrical cabinet looks very neat
  6. Billel
    Billel Member
    195Coins
    what electronical system did you use to control the motors ? arduinos, thanos board,.. ?
  7. Thanos
    Electronics Engineer
    2,907Coins
    Its using my old AMC1280 controller from 2016 !! Analog times :cheers
  8. Billel
    Billel Member
    195Coins
    i don't suppose you ship to Algeria
  9. Thanos
    2,907Coins
    Even if I did ship, I couldn't. I don't have any of these left since 2018... :roll
    We moved to inexpensive servo motor systems now, 100 times more accurate and 100 times faster to accelerate. And perhaps even cheaper than these VFD operated motors (about $200 set servomotor + servo driver + wiring)
  10. Billel
    Billel Member
    195Coins
    usable with AC motors ?
    153,740Coins
    The new @Thanos boards are for Servos, not AC: https://www.xsimulator.net/community/faq/amc-aasd15a-servo-controller.351/
  12. Billel
    Billel Member
    195Coins
    As far as i learned for this forum in the last two weeks, for DC motors simtools sends motion information to the arduino who controls the motors vias H-bridge system, all this is very clear on this forum. But what i can't figure out is how does simtools comunicate (or control) AC motors without the arduino/H-bridge system, i mean what's the electronical system used to achieve such results ?
  13. noorbeast
    153,740Coins
    It can't, SimTools can only 'talk' to control hardware in a known manner, that control hardware connects and controls a motor.
    For VFDs see the FAQ section: https://www.xsimulator.net/community/faq/vfds-and-3phase-motors.9/category
  14. Billel
    Billel Member
    195Coins
    ok, let's take for example the standard control hardware on the standard builds on this forum (Arduino Uno and H-bridge or sabertooth) system, for simtools to 'talk' to the control hardware (the Arduino) in the case of DC motors, we need a specific language installed to the Arduino (a sketch or a programme "the UNO file"), this program has 3 modes to choose from depending on the driver type used (IBT-2 or sabertooth) -this what i learned so far- , but what i still can't figure out is how to set up comunication between the arduino and AC motors driver/servo in case of AC motors build, is there an other sketch to be uploaded to the arduino ? or we can't use arduinos at all with AC motors.
    and thnk you in advance.
    153,740Coins
    Please VFDs see the already supplied link:
    Servos: https://www.xsimulator.net/community/faq/motion4sim-6dof-aasd15-servo-motion-controller.392/
  16. wyh0607b
    wyh0607b New Member
    173Coins
    AC motor, 6DOF
    thanos board
  17. Billel
    Billel Member
    195Coins
    plug and play, no need for programing, just seting up axis in simtools, right ?
