Showroom First 2DOF with SCN5
Discussion in 'DIY Motion Simulator Projects' started by Marcelo Keniti Takahashi, Apr 17, 2022.
  1. Marcelo Keniti Takahashi
    Marcelo Keniti Takahashi Takahashi
    São Paulo / Brazil
    - 24Coins
    2DOF, SCN5
    Greetings!
    I want to show you my first 2DOF that I build. I read and saw a lot of videos and texts from different sources to inspire me build this one. I think there are areas that i have to improve but I'm happy with the result.
    Sorry for my english, I'm Brazilian and I not use Enligh in my day.
    Items used:
    1-) Aluminium Profiles
    2 X 1370mm (Vertical bars / Inferior Structure)
    4 X 920mm (Horizontal bars / Inferior Structure)
    2 X 700mm (Vertical bars / Seat Structure) / This one i had to saw: 600mm
    3 X 360mm (Horizontal bars / Seat Structure)
    2 X 730mm (Base for SCN5)
    1 X 450MM (Seat base connected with the SCN5)
    1 X 350MM (Seat base connected with the SCN5)
    2-) 28 X Aluminium Profile's corner joint
    3-) Aluminium Profile's internal connector for corner joints
    4-) 4 Leveling foot (I choose one that is expensive but it's a dumper too)
    5-) Universal Joint
    6-) Pair of SCN5 (100mm)
    7-) Foam D33 (Density 33)
    :cool: 8 Rubber Mat 500x500mm (That one for crossfit :))
    9-) 4 Wooded Deck 500x500mm
    10-) A lot of screw/screw plugs (M8 and M10)
    11-) Power Supply 24V 6A
    12-) Pair of RS485 to USB
    Pics:
    Aluminium Profiles:
    Detail: Alumnium Profile's internal connector for coner joints (I don't know the name of this piece in English, sorry):
    Connection between Alumnium profiles and the internal connector:
    Building:
    Leveling foot and Corner connectors:
    Building:
    Marking holes for Universal Joint:
    Connecting the SCN5 with the structure:
    Base for Seat:
    Seat installed:
    Used Foam to attenuate vibration between seat and Structure:
    Rubber Mat/Wooden Deck to attenuate vibration to the floor (I live in an appartment):
    Power Supply and RS485 to USB:
    First test before building the sim motion (I uploaded as a short movie and can't embed here, sorry):
    Simtools test with scn5 - YouTube
    Second test with the structure:
    Simmotion Test - YouTube
    Problems after building:
    I tested with Left for Speed and SimTools crashed after 1 minute after playing. I checked the ILK pin, Bauds in the Com interface, got the logs from windows events but found nothing. After reading that I have to set my view to first person view (even though I have it that way), I suspected that VR or SimHub had changed something. I uninstalled the LFS and installed it again and it worked like a charm!
    I have to wait one more day to send a request of dyi license to play my beloved game (Assetto Corsa) and I am little anxious so I started playing LFS (I`ve never played this game before).
    LFS is a great surprise! With a GTX1080TI and a Pimax, I get 110fps, best experience ever with a sim and Vr!
  2. Marcelo Keniti Takahashi
    São Paulo / Brazil
    - 24Coins
    2DOF, SCN5
    Guide for Brazilians
    Coasts:
    SCN5 1150
    Universal Joint 114,05
    Aluminium profile 1150,24
    Corner Joints / Screws / Screw Plugs 248
    Internnal Connectors 200
    Screw Plug reduction 27,42
    Leveling Foot 107,7
    More Screws 168,6
    Where to buy :
    Aluminium profile : Forseti Soluções (forsetisolucoes.com.br)
    Rest of items: Mercado Livre Brasil - Frete Grátis no mesmo dia
    The universal joint was the piece that I didn't find anywhere because I didn't know this piece. So, you need to mount one using pieces of car (Portuguese: Cruzeta / Flange) or buy on named "Junta Universal".
    153,986Coins
    +11,161 / 57 / -2
    Great to see you have your rig moving :thumbs
    LFS does not go for hyper real graphics so is great for VR, and was one of the earliest games to implement VR support.
