luu trung's project
Discussion in 'DIY Motion Simulator Projects' started by luu trung, Apr 21, 2022.
  1. luu trung
    luu trung Member
    172Coins
    I have 3 motors like you and am planning to make 3 motors and 1 cardan shaft in the middle like this video, is it possible? The motor lever will be pushed down when there is no power, and when there is power, what will happen? Is this motor different from wormgear motor? Can't move the boom without power. Please reply
    151,467Coins
    +11,038 / 56 / -2
  3. luu trung
    luu trung Member
    172Coins
    thanks for the reply.
    I am a new member. I only ask questions on sites like my project. I don't know where to ask.
    151,467Coins
    +11,038 / 56 / -2
    No problem, ask all of your questions related to your project here, that way all of the information concerning your project is in one place.
  5. luu trung
    luu trung Member
    172Coins
    Hi guys. after about a year of reading the documentation and asking a few questions on the forum. I did the same as above video but with wheelchair motor. I'm stuck at SMC3 and don't know what to do? ?
    motors 1 and 3 rotate in opposite directions and motor 2 does not work.
    when pressing "ON" 2nd motor, 3 motor rotates a bit and then turns off
    Hope everybody help please
  6. luu trung
    luu trung Member
    172Coins
    I don't know how to upload video clips
    151,467Coins
    +11,038 / 56 / -2
    151,467Coins
    +11,038 / 56 / -2
    Rotating in opposite directions is likely a wiring issue.
    Can you please post pictures of all of your SMC3 settings.
    For the motor that does not work you can swap hardware between those that do work and those that don't work to try and pin the issue down.
  9. luu trung
    luu trung Member
    172Coins
    When I disassemble the 3 sensors, is it normal for the 3 motors to rotate like that?
    -When attached, the motor rotates beyond the 5v threshold of the sensor, the motor turns off.
    - my smc3 settings
  10. luu trung
    luu trung Member
    172Coins
    my setting smc3 sensorless mode
    151,467Coins
    +11,038 / 56 / -2
    The video looks to be private, likely you need to reconfigure the Youtube settings.
  12. luu trung
    luu trung Member
    172Coins
  13. noorbeast
    151,467Coins
    +11,038 / 56 / -2
    Seems like the motors are not staying within SMC3 boundaries, is that correct?
  14. luu trung
    luu trung Member
    172Coins
    I don't quite understand about scm3.
    Is it ok for motor number 3 to work like that?
    motor 1 and 2 when attached to the sensor rotate a bit and then turn off
  15. luu trung
    luu trung Member
    172Coins
    What is scm3 yellow line? it crosses the red line
  16. luu trung
    luu trung Member
    172Coins
    - hello. can you guide how to adjust the sensor rotation when connecting to the motor? -
    when I adjust the 2.5volt sensor attached to the horizontal lever rotate over limit of smc3. engine turn off
    help me
    151,467Coins
    +11,038 / 56 / -2
  18. noorbeast
    151,467Coins
    +11,038 / 56 / -2
  19. luu trung
    luu trung Member
    172Coins
    hi. can you explain why the yellow line of motor 1 and 2 is at the bottom. Not in PWMmin and PWMmax. only 1 motor number 3 is in the PWMmin and PWMmax region
  20. luu trung
    luu trung Member
    172Coins
    hello.how to enter liveforspeed game?
