motor for linear actuators?
Discussion in 'Motor actuators and drivers' started by tadeusz, Dec 28, 2021.
  1. tadeusz
    tadeusz New Member
    34Coins
    Hi
    Is this motor suitable for linear actuators?
    Maybe someone knows the parameters of these engines?
    greetings
    Tadek
  2. Gadget999
    12,132Coins
    2kw is a lot of power !
    are they a engine starter motor ? what are they used for ?
  3. tadeusz
    tadeusz New Member
    34Coins
    hi
    This is the engine from the car elevator. Drives the hydraulic pump.
    • Disagree Disagree x 1
  4. tadeusz
    tadeusz New Member
    34Coins
    like this
  5. tadeusz
    tadeusz New Member
    34Coins
  6. tadeusz
    tadeusz New Member
    34Coins
    the price is good about 25 EUR
  7. tadeusz
    tadeusz New Member
    34Coins
    parameters :
    Total length (mm) 169
    Length of the armature housing (mm) 115
    Diameter of the armature housing (mm) 80
    Number of terminal clamps 2
    Front flange NIE
    Type shaft front B
    Number of plugs 2
    Cooling fan none
    Minimum voltage U1 (V) 24
    Current (ampere) (A) 76
    Power (kW) 1.2
    Motor type pump motor
    Insulation grade (IP) 44
    Insulation class F
    Direction of rotation CCW
  8. Gadget999
    12,132Coins
    Thats a very good price
    Buy one and try it out
  9. tadeusz
    tadeusz New Member
    34Coins
    Hi
    I think Turnover per minute 3500 !!! is too high?
    Whether there is a change of direction of rotation in these motors
    when the power supply polarity changes?
  10. tadeusz
    tadeusz New Member
    34Coins
    Unfortunately the minimum purchase is 5 pieces
  11. tadeusz
    tadeusz New Member
    34Coins
    hi
    Direction of rotation is CW
    Is it problem?
  12. OzzyO
    OzzyO New Member
    ARGENTINA
    - 25Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    i think that ist dificult to run these motor because they have a lot amps necesity.
    its posible but you have to look for one h bridge that run with 2kw.
    Best regards
  13. OzzyO
    OzzyO New Member
    ARGENTINA
    - 25Coins
    Other problem that i can see its that you will need a very big power source to run 100A even at 24V
