ChrisOmaha 2DOF Build Thread
Discussion in 'DIY Motion Simulator Projects' started by ChrisOmaha, Mar 28, 2022.
  1. ChrisOmaha
    ChrisOmaha New Member Gold Contributor
    - 76Coins
    Building a 2DOF sim with my sons. Specs so far are ibt2 controllers and jazzy wheelchair motors. Frame is built from 1 inch square tube and a steering u joint. The seat is from Summit Racing. I purchased a 24v LED power supply but smoked both IBT2s, working better with a 12v battery for now but still have not settled on a power supply or possibly different controllers.
    Just got to the point where everything is tack welded together enough to test motion and geometry. It will get a little more bracing but everything seems to work well already.
    PXL_20220305_201351643.MP.jpg PXL_20220306_194028232.jpg PXL_20220309_033102879.MP.jpg PXL_20220319_190335557.MP.jpg PXL_20220319_190340360.jpg PXL_20220319_192700861.jpg PXL_20220327_230232602.jpg
    153,938Coins
    +11,158 / 57 / -2
    Great to see your rig in action :thumbs
    You may need to re-balance your rig once all peripherals are added, particularly with a compact design, which has limited inherent design leverage.
    What are you using as a uni-joint?
  3. ChrisOmaha
    - 76Coins
    The U joint is a steering linkage off some car at the junkyard. Didnt actually even see what the car was, just saw one what was in very good condition and was a little bigger then some others and easily accessible. I cut the bottom off of its shaft to weld onto the seat side, then use the pinch bolt to attach it to the seat frame while still being easily detachable. So far so good, no play in it at all.
    This last week my eldest son completed all of the bracing and welding. Then my younger sons helped me paint and mount the pedals.
    I wired up some HP DPS-600pb power supplies to replace the car battery from the last test.
    Now it just needs more testing and tuning. May shorten the CTC arm a little more as the axis is currently limited by the nose hitting the ground so we could probably decrease backlash and increase resolution with a shorter arm. Otherwise its near ready to go.
    PXL_20220410_233122519.jpg PXL_20220411_130541749 (1).jpg PXL_20220410_202120986.jpg
    PXL_20220410_182539286.MP.jpg PXL_20220410_174458265.MP.jpg PXL_20220412_004400297.jpg PXL_20220412_010547578.jpg PXL_20220412_010948431.jpg PXL_20220412_030219583.jpg
  4. ChrisOmaha
    - 76Coins
    Made a little more progress this weekend. The IBT2 controllers were regularly cutting out under aggressive loads such as crashes so I upgraded to two Cytron MD20A motor drivers which offer 20 amp continuous and 60 amp peak. So far these have been a great upgrade for the price. We put them through repeated violent crashes for a few hours and could not get them to trigger over current or raise their temp much above room temperature, even without heatsinks.
    I did manage to trip the HP power supplies a couple times but only with a smaller child and once when the chair was actually unloaded. I guessing its not actually load related but may be a regenerative spike during fast reversals that may be making them upset. I may try adding some large capacitors although it has not been a regular issue.
    I also played with monitor combinations. The quest headset makes me motion sick and limits games. I acquired a cheap 27" monitor and experimented with mounting to the frame but I feel like I may actually prefer the monitor not moving and actually liked it better on the desk. I may build a static stand that holds it just over the sim.
  5. Takumivs
    Takumivs Project CPT
    Mechatronics / Mechano Engineer
    South Africa
    38Coins
    2DOF, 3DOF, DC motor, AC motor, SCN5, SCN6, Arduino, JRK, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    Howsit gent I trust yo are well, I need abit of assistance if possible to help figure out on SMC3. when put the pots green line onto the blue line turning power on the motor jump aware from the lines, the more i try to adjust the pot to the blue line the motor goes one direction away from the line. using mode1 on the SMC3 settings...thank you kindly my gent. I take you using SMC3 firmware with mode1
  6. ChrisOmaha
    - 76Coins
    Yes, I used mode 1 with the Cytron controller.
    I only used the pins below on the Arduino.
    9 Motor 1 PWM (PWM)
    2 ENA Motor 1 (Direction)
    10 Motor 2 PWM(PWM)
    4 ENA Motor 2 (Direction)​
    If its going away from the line you can reverse the motor + and - at the controller to reverse the motor direction. Or I believe you can also use ENB which is inverted in Mode 1.
  7. ChrisOmaha
    - 76Coins
    To solve the power supplies randomly tripping I added Pololu shunt regulators, specifically the 13.2V 15W.
    The shunt regulators with the Cytron/HP power supplies seems to be a reliable combination so far. I probably have a few dozens hours of use with no hiccups since adding them.
  8. Takumivs
    South Africa
    38Coins
    Yah thanks my gent, im currently using pin 3 an pin 5 which i tried pin 2 and 4 but wasnt doing anything. will give that a shot and see if it was a wiring issue. thanks a million gents
  9. Takumivs
    South Africa
    38Coins
  10. Takumivs
    South Africa
    38Coins
    Im using 2 x 24v 15A psu, the fans in them determine load by how loud they get and so far its been super quiet when i had them running with IBT's but pop two that i upgraded to cytron MD20A which worked off the bat but for some reason the one motor kept going out of range when i was braking for corners on ac. and that where discovered that i cant get the pot line to much the blue line on SMC3 which open a whole bag of worms.lol.
  11. Takumivs
    South Africa
    38Coins
    Found the issue, the expansion board i was using became faulty, i wired a pot to see what it was doing and saw the board would short out when fully maxed the pots. now its work again without the expansion board.
