Simtools v3 RF2 plugin
Discussion in 'rFactor' started by Gadget999, May 8, 2022.
  1. Gadget999
    12,035Coins
    I am a busy guy but I do plan to do a new plugin for RF2 for the new version of simtools
    I am using this thread to store information that may be useful, if anyone has suggestions or and thing to add please leave it here :)
  2. Gadget999
    12,035Coins
  3. Gadget999
    12,035Coins
  4. Gadget999
    12,035Coins
    Last year i wrote a telemetry app for RF2
    It logs lots of info about the car and driver and displays a map showing where the car is etc.
    It uses the rf2 shared memory map dll
    Is there any reason an exe could not be used as a plugin rather than a dll ?
    If i program a transfer of the data to udp this may well work as both a plugin and a telemetry app
    @yobuddy - what is your opinion ?
  5. Gadget999
    12,035Coins
    @noorbeast any suggestions ?
  6. yobuddy
    51,176Coins
    You would still need a dll for simtools to load and use the plugin.
    The plugin could however use an exe to send data if needed.
    But using the shared memory map directly would be a lot easier I think. (Unless I'm missing something)
    Take care!
  7. Bradabong
    Bradabong New Member Gold Contributor
    - 32Coins
    4DOF
    Hello, I’ve updated sim tools to V3 and in Rfactor 2 I’m getting motion input from the steering wheel sat still in the pits, and if I move the car forward the motion is going in all sorts of different directions… I have Asetto corsa working fine… any ideas what I’m doing wrong?
    Many thanks
    Brad
