Problem simtools
Discussion in 'Forum and Website' started by nanofico, Jun 6, 2022.
  1. nanofico
    nanofico New Member
    - 24Coins
    Hello everybody. I have a problem with simtools, practically yesterday I set the various parameters (pitch, roll, sway and surge) and tried with the live game for speed everything worked perfectly. today i'm going to play and all the settings have remained the same on simtools but almost nothing works in the game especially the surge is stopped. What could it be?
    152,535Coins
    +11,085 / 56 / -2
  3. nanofico
    nanofico New Member
    - 24Coins
    good evening, here are the following simtools settings
      157.1 KB
      346
      151.4 KB
      319
      153.7 KB
      330
      145.9 KB
      330
    152,535Coins
    +11,085 / 56 / -2
    What are the Tuning Center values while the game is running?
  5. nanofico
    nanofico New Member
    - 24Coins
    in the tuning center the value is calculated. could it be a problem with the simtools version or my pc not having enough power to make everything work? I've also noticed that full-screen LFS engines lose power.
    152,535Coins
    +11,085 / 56 / -2
    If the Tuning Center shows game data it would be helpful to see what it is.
    Is the computer set to English Local: https://www.xsimulator.net/community/faq/simtools-language-setting-bug-change-to-english-local.233/
    Changing to full screen in LFS should make no difference on a average gaming computer, as LFS is a fairly lightweight game compared to more modern simulation titles, but may have an impact on a low spec computer, what are the specs of your PC?
  7. nanofico
    nanofico New Member
    - 24Coins
    the pc is not set to english local. the pc I use to configure is a laptop not suitable for gaming. lfs runs fine.
  8. nanofico
    nanofico New Member
    - 24Coins
    these are the characteristics of my pc
      80.7 KB
      321
      69 KB
      335
      71 KB
      320
  9. nanofico
    nanofico New Member
    - 24Coins
      110.8 KB
      320
    152,535Coins
    +11,085 / 56 / -2
  11. nanofico
    nanofico New Member
    - 24Coins
    what I don't explain is why the day before everything was perfect and the day after it didn't go anymore.
    152,535Coins
    +11,085 / 56 / -2
    My guess would be accidentally triggering a Max/Min capture in the TC.
  13. nanofico
    nanofico New Member
    - 24Coins
    now I proceed with the reacquisition of the min / Max I make the adjustments as you told me and I update you. for now thank you very much
  14. nanofico
    nanofico New Member
    - 24Coins
    hi noorbeast thanks for the advice. the problem was an unintentional min / max capture. I redid the settings now everything works fine. thank you very much
  15. Gerardo Rivera
    Gerardo Rivera New Member Gold Contributor
    114Coins
    I bought Njmotion SV-F tried to fine tuning but still motion are rough.
  16. noorbeast
    152,535Coins
    +11,085 / 56 / -2
    If the motion feels too sharp and jerky then use slightly higher values in the Tuning Settings.
