Another 2DOF (with USA-based sources)
Discussion in 'DIY Motion Simulator Projects' started by congb17, Apr 9, 2022.
  1. SaintFrank
    SaintFrank Active Member
    Proces operator
    Nederland
    232Coins
    Thx Congb17
    Does your rig also feel choppy in the SMC3 utility or only in-game? Mine was very smooth in the utility but choppy in game until I turned on the smoothing filter. Anyway, hope this helps![/QUOTE]
    Movement in smc3 and in-game is smooth if it is has a big change (saw, sine move), when slowly leveling I feel tiny steps .
    I'll try your settings and see if that makes a difference.
  2. Kevin123
    Kevin123 New Member Gold Contributor
    Computer Programmer
    Colorado
    58Coins
    Ahhh the official SMC3 thread with the latest release... How did I miss that...
    It looks like soft-start is not included in the 1.0 release, is that correct? Is it not needed?
  3. luu trung
    luu trung Member
    172Coins
    hi. how does the high and low input clip affect the motor
    153,980Coins
    +11,160 / 57 / -2
  5. Vitalius
    Vitalius Active Member Gold Contributor
    Bonn
    540Coins
    Motion platform, 6DOF
    Hello good idea with TV mount. Does the TV mount hold tight and won't give way? I want to use something like this for my touch monitor.
  6. congb17
    congb17 New Member Gold Contributor
    Engineer
    California, USA
    163Coins
    It does, but I 3D printed supports and tightened the bolts extra tight. That's probably not necessary for the stick, but definitely helpful for the wheel.
  7. iLLuac4
    iLLuac4 Active Member
    891Coins
    Hi. Can you please share arduino program for esp28266 pwm for simhub? TNX
  8. congb17
    Engineer
    California, USA
    163Coins
    Sure thing, for the fan, right? See attached. Use at your own risk. I hope this is helpful!
