3DOF Arduino motion platform project
Discussion in 'DIY Motion Simulator Projects' started by Mechatronik, May 2, 2022.
  1. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Hi, month ago I decided to build my own motion platform. I was looking for information how to build it and found xsimulator forum and D Max on Youtube. I want to create something like this:
    So far I made a 3D model and I'm gathering parts. I want to do DIY FFB steering wheel too. I want to use arduino for motion platform and stm32 for steering wheel. It will be an interesting summer. :)
  2. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    So far so good. I welded 3 frames and finished belt FFB steering wheel. Now it's time for wiring everything up. I hope BTS7960 will work with 24v 350W motors. Seat I used is testing purpose only, if everything will work, then I will buy bucket seat.
    • Like Like x 5
  3. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I tested driving position and it is just right. Unfortunately 3D printed quick release system from my old ffb steering wheel failed. Old one had 100W motor, now it is 24v 350W. 287125365_1445770232542939_4853476770866885543_n.jpg
  4. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I designed 3D model with m8 screw reinforcement . I hope this time it will last longer, otherwise I will buy normal quick relese like in real cars. Tomorrow I will print and test it.
    287404144_506307334512021_8439346360001079687_n.png 287210984_1727149540978811_1940405222439872712_n.png
  5. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    New quick release is ready. Connection is really tight, but easy to unconnect with bike seat clamp. I'm satisfied with this part.
    Next I'm going to do cooling and control box.
    • Creative Creative x 2
  6. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I drilled holes in box and mounting plate for better cooling. I will use two 24V fans for cooling.
    287965815_584601579755105_8625423205995713142_n.jpg 287230182_434866951794574_4055175396093338272_n.jpg
  7. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Power supplies, relays and fans on place. Next step: more radiator, thermal paste for IBT-2 modules and WIRING! :)
    288669878_351205883839983_2591952524641637263_n.jpg 287235630_871429240384761_3468409225012004539_n.jpg
  8. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    BTS7960 heat sinks done and mount for them.
  9. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Wiring for first BTS almost done. I need to repeat this process two times, but I enoy it :).
  10. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Power line wired up. Arduino wiring and BTS->motors left.
    Here is my wiring diagram for Emergency Stop:
  11. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I have Arduino NANO so I will use it, because it is the same microprocessor like in UNO just smaller pcb. I soldered board for wiring with jumper wires.
  12. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Everything wiried up :). First test done, 3 motors running in good direction. I'm getting close to first motion test .
  13. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Motor 1 and 2 have 25kHz frequancy, but Motor 3 has got only 4kHz and 31kHz option. BTS7960 is up to 25kHz. Can I set some how 25kHz on motor 3 as well?
  14. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Motor was overheating too fast, so I had to use shorter arm. Now it's ok I think.
  15. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I'm after first "ride", looks promising. I have to tweak setting, but overall I'm getting somewhere.
  16. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    Great to see your rig in action, well done :thumbs
    Just some suggestions, it looks like sway needs tweaking, it should lean away from a corner, and roll gets set the opposite of sway. Some heave would also add to the immersion.
  17. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    I think I have driveable settings for now. Surge is jerky, but I think it is because I used keyboard so far. In next test I want to use steering wheel and VR.
  18. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    Excellent progress :thumbs
    I agree, the surge axis allocation looks overdone, perhaps a smaller Axis Allocation % and smaller Tuning Center values would tighten surge up, see the FAQs re snappy gear changes: https://www.xsimulator.net/community/faq/snappy-gear-change-motion.121/
  19. Kenshiro27
    Kenshiro27 Active Member
    252Coins
    2DOF, 3DOF, Arduino
    the chassis for the loss of traction is well thought out and the skateboard wheels are really well seen:thumbs
  20. Mechatronik
    Mechatronik Member
    Student
    Poland
    - 25Coins
    Thanks :), few days ago I started to use traction loss and it is awesome. Just need some tweaking.
