Question my engine loses power
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Pedro Fuhs Benini, Jun 28, 2022.
  1. Pedro Fuhs Benini
    Pedro Fuhs Benini New Member
    14Coins
    my motor loses power and falls when i sit on the bench, can someone help me, they are wheelchair motors, 24v/70a source, ibt2 h bridge, arduino uno
  2. Pedro Fuhs Benini
    14Coins
    It works perfectly, when the weight of the body is placed, it stops working, as if the engine turns off.
  3. SaintFrank
    SaintFrank Active Member
    Proces operator
    Nederland
    232Coins
    Is the rig balanced with you on it?
    Maybe that would take some load of the motors.
    What is the power (Watts) of the motors?
    Sounds like it draws to much currant( amperage) .
  4. Pedro Fuhs Benini
    14Coins
    The motors are around 300 watts with a reduction of 32/1 each, I use a 24v 70a source, I put car batteries for testing but it was the same thing, it could be the SMC3 configuration, it works well but suddenly it falls apart
  5. SaintFrank
    Proces operator
    Nederland
    232Coins
  6. Pedro Fuhs Benini
    14Coins
    Yes it follows the sinusoid perfectly for a while, at some point I notice as if the motor stops and loses the reference, could it be the ibt2 h bridge heating up? , when the bridge h warms up could it stop sending pwm ? , I'm using b10k potentiometers. I will make a video
  7. SaintFrank
    Proces operator
    Nederland
    232Coins
    Ibt-2 can handle up to 27V , but if they getting hot that is not a good sign,
    I reduced voltage to my ibt-2 to 21V
    This minimalizes the heat generation , mine are not warm at all.
    I think the potentiometers are not the problem.
    You can check the pots:
    no power to the motors and rotating motor by hand , check their movement in SNC3.
    Maybe change an ibt2 or the arduino see if that makes any difference.
    and meassure the load (amperage) of the motor.
  8. Pedro Fuhs Benini
    14Coins
    I did a new test, my power supply works at least at 24v, I put a fan on the ibt2 bridges, in the ammeter test it reaches 3 amps and the motor is turned off, in theory the bridges are 43 amps and my supply 70 amps, it shouldn't there is this stop in the engine
  9. wimpo`
    wimpo` Member
    metselaar
    nederland, twente, vroomshoop
    178Coins
    Could be that the PSU is shutting down because of voltage received from motors when slowing down. This can easily exceed the supply voltage voltage. Some PSU can't handle that well. The bts7960 also doesn't like it much from what I read. A battery can handle this. Maybe the USB cable wich is pretty close to to the PSU lines, emi? Bad ground connection somewhere so could be a ground loop. I don't know exactly what the switch between the PSU line is. Looks like a 230v 16a breaker. Maybe it's faulty. Try to use one moter with the PSU so you know that it isn't the motors back emf that is working against each other. Just my 2 cents.
  10. nmk
    nmk New Member
    61Coins
    2DOF, 3DOF, DC motor, SimAxe, Arduino, Motion platform
    good morning, it could be the weight of the whole body on top of the motors, the chair needs to be at a well balanced angle, when I did my project the same thing happened, then I changed the angle of the chair so that all body weight would not be on the motor and it worked, I hope could have helped
    • Optimistic Optimistic x 1
  11. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    You could try some light weight gas struts to help hold you up during static time. dont go too strong tho or you sim wont be able to move lol. I think Im using 40 pounders on my 6 d0f and that seems right on the brink, but I havent tested with me in it yet tho either.
    also. your Ibt-2's could be going out. Im having a hell of a time with thos burnin out on me. Im swithing to the 30A cytron motor drivers myself. They are packed with features and never need cooling.[/QUO
  12. Pedro Fuhs Benini
    14Coins
    I already changed everything, checked everything, and I don't find the problem, the 2dof works but suddenly I have to restart and it starts working again, the motors generate reverse energy could this be the problem, it would be as if the ibt2 h bridge goes into protection and turns off, closing smc3 and starting again the system works again.
  13. nmk
    nmk New Member
    61Coins
    HELLO EVERYONE, I HAD THIS PLOBLEM ALSO YOU NEED TO LOWER THE POWER OF THE ENGINE IN THE SMC3, IN CASE WHAT IS TURNING OFF, I HOPE I COULD HAVE HELPED.
  14. Pedro Fuhs Benini
    14Coins
    how can i lower the engine power in smc3? what configuration did you use?
  15. Pedro Fuhs Benini
    14Coins
    Hi nmk ,
    could you tell me your smc3 settings?
  16. noorbeast
    153,716Coins
    Can you please post pictures of all of your SMC3 settings.
    If it is cutting out in
    Please post pictures of al of your settings, that will help other in giving advice.
  17. nmk
    nmk New Member
    61Coins
    good morning to all of the forum, my friend my configuration is like this Kp=50,Ki=50,Kd=50,Ks=1, PWMin=70,PWMmax=110,PWMrev=70 ,Max Limits=0 ,Clip Input=200 , Deadzone=0 , this is my configuration , depending on the engine it changes , so you need to do your configuration, hope I helped .
      371.4 KB
      288
  18. noorbeast
    153,716Coins
    The SMC3 settings are explained here: https://www.xsimulator.net/communit...driver-and-windows-utilities.4957/#post-48121
    You have Max Limits at zero, which needs to be fixed, as if the set value is exceeded it will shutdown the drivers:
    Max Limits Used to create a band at either limit of the feedback range beyond which if the motors move (typically through inertia) the SMC3 will automatically shutdown the drivers and keep them disabled until reset. This is essentially a safety mechanism if something goes wrong.
  19. nmk
    nmk New Member
    61Coins
    Hello everyone on the forum, yes I will correct it, thank you very much for the tip.
  20. Fdmml
    Fdmml Member
    143Coins
    I don't know if your problem is solved.
    If not, then try to decrease your Fpwm to increase the power to your engines.
    I had the case, the motors ran normally no load and when I put weight on they went to safety.
