Question MY1020 DC DD Build
Discussion in 'DIY peripherals' started by GSXR, Jul 1, 2022.
  1. GSXR
    GSXR New Member
    75Coins
    DC motor
    So I've been browsing around for the past two days at people's builds and bought an 800W 48V MY1020 along with a HP ProLiant DL585 G2 1300W as I saw a post on RCgroups using the same and converting it to High amperage here's the post https://www.rcgroups.com/forums/sho...high-quality-12Volt-100Amp-Power-Supply-Part1
    But my question is what else will I need to run the wheel in DD, could I get a parts list or a link to someone who has done a my1020 DD build with a parts list, cheers.
  2. GSXR
    GSXR New Member
    75Coins
    DC motor
    I see people normally use the Omron E6B2-CWZ1X but I cannot find any, but I can find the E6B2-CWZ6C would it make a difference or exact same?
  3. GSXR
    GSXR New Member
    75Coins
    DC motor
    So far I've ordered 800W 48V MY1020, HP ProLiant DL585 G2 1300W Power supply which will be converted to run at 12.77v 118A (According to the forum post) along with a stm32f4discovery, and I saw a post about BTS7960B's my question is how many would I need, this person running 100A was using 2-3 in Parallel would that be suitable in my case or overkill? am I missing anything?
  4. GSXR
    GSXR New Member
    75Coins
    DC motor
    Forgot to mention I also ordered an Omron E6B2-CWZ6C
  5. GSXR
    GSXR New Member
    75Coins
    DC motor
    Since I didn't get an answer I went along and ordered Four BTS7960's which will be ran in parallel (Going off of info from manu79's Drivingitalia MY1020 DD build) , also ordered STM32F0 Discovery board since I wasn't able to find any info on which to pick.
  6. ba114
    ba114 New Member
    196Coins
    DC motor
    I ordered a 2000ppt version of the Omron E6B2-CWZ6C for my hoverboard project
  7. GSXR
    GSXR New Member
    75Coins
    DC motor
    I have ordered everything for it, but cannot find a wiring diagram/schematic to follow, and almost every topic I find for my1020 builds aren't in English and the translation is pretty meh
  8. Gadget999
    12,371Coins
    Search for 'Cousin of OSW'
    All the answers you need will be there
  9. GSXR
    GSXR New Member
    75Coins
    DC motor
    Hi there thanks I'll check it out, is there any specific page I should start at?
  10. GSXR
    GSXR New Member
    75Coins
    DC motor
    So as an update of bumping my own dead post, I have the majority if not everything required to make the Hub which I shall be 3d printing the enclosure for the electronics and using a fan on the back of the motor near the Encoder. I do actually have a question to those that have some a similar project with the 1000W or 800W variant of the MY1020, What Nm of torque did you get and what amperage were you running it at? what was the clipping like?
    Software: ebolz magy EMC
    Parts List:
    • MY1020 48V 800W Motor
    • Omron E6B2-CWZ6C
    • Four BTS7960s
    • ProLiant DL585 G2 1300W PSU (Model: HSTNS-PA01 406421-001 337867-501)
    • STM32F407VETG
  11. GSXR
    GSXR New Member
    75Coins
    DC motor
    Had the parts for a while just been struggling to find a wiring diagram on what to connect, where to connect, and the wire to use, I believe I have 4AWG for my PSU, and 10 or 12 for the rest of the wiring, the BTS7960S would be ran in parallel and I do not believe I will use Four, possibly three
