F1 2022
Discussion in 'Other Racing Games' started by Specter20, Jul 3, 2022.
  1. Specter20
    Specter20 New Member Gold Contributor
    Heavy Equipment
    Canada
    - 22Coins
    Is it safe to say that the plugin for F1 2021 will work for F1 2022?
    153,974Coins
    +11,160 / 57 / -2
    I have not heard of anyone getting it to work.
    There is an initial F1 2022 plugin for SimTools v3, but that is not backward compatible with SimTools v2, with v3 just about to exit closed Alpha testing into Beta testing.
  3. Chris Twigg
    Chris Twigg New Member
    - 87Coins
    I’d be interested in getting it working. Have you found any info on it?
    153,974Coins
    +11,160 / 57 / -2
    Please see my previous comment: https://www.xsimulator.net/community/threads/f1-2022.17179/reply?quote=229589
    The test plugin for v3 of SimTools works in desktop mode, but not in VR yet, so for those of you interested in F1 2022 what would be helpful is identifying the process name for the VR side of the game, while it is running in VR mode.
  5. Specter20
    Heavy Equipment
    Canada
    - 22Coins
    Cool, thank you for this info. I appreciate whoever is working on it
    153,974Coins
    +11,160 / 57 / -2
    @yobuddy in particular and the SimTools dev team deserve the credit, along with those assisting in testing.
    There is lots of work going on with SimTools v3, which ultimately requires all plugins and any new ones to be redone for v3, so it is great you are thinking of those doing the hard yards, and despite our collective excitement and anticipation we all do need to allow a bit of time for those people to work their magic.
  7. Chris Twigg
    - 87Coins
    It's not a different exe for VR mode. It looks like it's just a /VR in steam switch to start the exe
    153,974Coins
    +11,160 / 57 / -2
    Excellent, that should make @yobuddy's life a little easier.
  9. yobuddy
    51,551Coins
    Turns out there is a vr specific file that also need to be patched.
    I will take some time today to put together a test v2 plugin so you guys can get to playing!
    Chat latter guys!
    • Winner Winner x 3
  10. yobuddy
    51,551Coins
    F1 2022 plugin posted!
    Let me know if you have any problems...
  11. Jean-pierre Piquionne
    Jean-pierre Piquionne New Member Gold Contributor
    - 116Coins
    3DOF, Arduino
    Hi yobuddy. I use game vibe but I no longer have data going back to the game vibe tuning center. It worked at first when installing the plugin. game engine is still ok. I don't know if an update of f1 22 is the cause.
  12. Jean-pierre Piquionne
    - 116Coins
    3DOF, Arduino
    Udp format Legacy or 2018 it's the same thing.
  13. yobuddy
    51,551Coins
    2018 is the format it was meant for.
    Have you tried closing and reopening game vibe when the game and simtools is running?
  14. MasterYoda
    MasterYoda Active Member Gold Contributor
    Portland/USA
    322Coins
    2DOF, SCN5
    Thanks a lot for this plugin @yobuddy
    It worked for me non-VR, still pending VR testing...
  15. estanislaolopez
    estanislaolopez Member
    Argentina
    80Coins
    2DOF, DC motor, SimforceGT
    Is working F1 2022?
