F1 2022 v1.0
F1 2022 GamePlugin for SimTools
  1. yobuddy
    51,676Coins
    yobuddy submitted a new resource:
    F1 2022 - F1 2022 GamePlugin for SimTools
    • Like Like x 6
    • Winner Winner x 3
  2. bruno1210
    bruno1210 schumi06
    103Coins
    I will test the plugin thank you very much
  3. Rongchen
    Rongchen New Member
    67Coins
    Happy to update that the plugin works perfectly in both desktop and VR mode! Thanks so much!!
  4. bruno1210
    bruno1210 schumi06
    103Coins
    top works more accurately why udp 2018 and not 2022 thank you
  5. Rongchen
    Rongchen New Member
    67Coins
    Plugin works in both legacy and 2018 format from previous versions. I don’t know exactly the reason but I remember there were discussions around this in plugin 2021 & 2020 discussions. You might wanna check them out.
  6. Jean-pierre Piquionne
    Jean-pierre Piquionne New Member Gold Contributor
    - 116Coins
    3DOF, Arduino
    hello. great for the plugin. for me, unfortunately it does not patch. maybe because of the directory name."F1 22" instead of "F1 2022" I use simtools version 0.2.4.0. executable of the game "F1_22.exe". do you have a solution for me?
  7. yobuddy
    51,676Coins
    Have you run the game and played a race?
    If not, afterwords, select the 'F1 22' folder in you pic above.
    Take care!
  8. Rongchen
    Rongchen New Member
    67Coins
    manually select the F1 22 folder and you are patched.
  9. Jean-pierre Piquionne
    - 116Coins
    3DOF, Arduino
    thank you. it works now. indeed I had selected "F1 22\savegame" instead of "F1 22". Thanks again to everyone
  10. Blekkulf
    Blekkulf Member Gold Contributor
    Molde
    342Coins
    2DOF, AC motor, Arduino, Joyrider, 6DOF
    Thanks for the plugin yobuddy! Im testing vibe now. Seems to get signal, but the labels are not set. Cant see witch input is RPM and Chassis :)
  11. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    611Coins
    2DOF, 3DOF
    Hi there,
    Quick I try tonight
    Thanks.
  12. Suglock
    Suglock New Member
    46Coins
    Thanks for this plugin.
    In udp 2022 it does not work..
    You have to upgrade to udp 2018.
    You know why ?
  13. Nocelo
    Nocelo New Member
    45Coins
  14. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    Hi there,
    I tried the F1 2022 plugin but I have the same problem as F1 2021 on my career mode my team the seat does not work in 2018 mode and in 2022 mode it sends information to the seat which is weird and you have to crash the jacks .
    anyone encounter this problem.
    solo in 2018 mode no problem.
    thank you.
  15. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
    single player career mode with normal stable
  16. DE CASTRO
    Cahors France
    611Coins
    2DOF, 3DOF
  17. Suglock
    Suglock New Member
    46Coins
    Hi there,
    The plugin only works if I select the UDP Legacy or 2018 option; if I place the UDP in 2022 it does not work but my jacks shake without movement.
    It's a shame because I can't use Simhub because it needs to have UDP in 2022 and not in 2018.
    You have an idea why in 2022 it does not work and that I have to place the UDP setting in 2018 because in fact I cannot use my dashboard with Simhub and simtool
    Thx for your help
    Best regards,
  18. paulopsx2
    paulopsx2 Active Member
    brasil
    648Coins
    the same here. i willl try simdash
  19. paulopsx2
    brasil
    648Coins
    ok. simdash dont have free virtual dashboards...
    and sim hub only works with 2022 option.
    so sad.
  20. Blekkulf
    Molde
    342Coins
    I have no signal from the game. Checked the UDP settings, enabled vibe in game manager. Game manager show that the game is running, but i get no signal when i try to capture high/low in Game Engine or Vibe. When i run Dirt or another game it captures both. The patch was succesful.
  21. Blekkulf
    Molde
    342Coins
    Found the problem. Sim dash was running in the background from my other sim, and blocked the udp i guess. Will try with this progam to solve the issue; https://www.eksimracing.org/srps/
    Mabye this will solve some of the other udp problems in the thread too :)
