SMC3 Hall Sensor issue
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Dr4g0r, Jun 29, 2022.
  1. Dr4g0r
    Dr4g0r New Member
    483Coins
    Hi, i have a problem with the hall sensor in the SMC3 (MODE2) program. I bought hall sensors on the LM393 PCB with analog and digital outputs because I have to limit the angle of the motor due to its design, I decided to buy them because they are relatively cheap compared to hall pots. Everything works fine on ordinary pots, after connecting the hall sensor, the engine does not respond and gets strange readings in the SMC3 program. Need to change something in the code? Or should I use a different sensor?
    153,830Coins
    +11,151 / 57 / -2
    Can I check the hall sensor is centered at rest and confirm what number of degrees is its range?
  3. Dr4g0r
    Dr4g0r New Member
    483Coins
    Sorry for long reply but during this time I bought the proper hall sensors and did something like an inverted potentiometer. everything works quite fine, after the initial configuration i get a graph like below, is it okay? The only thing that bothers me is a slight squeaking from the motor, so far only one is plugged in. The swing range is about 40 degrees (20 up and 20 down) or a little less
  4. Gadget999
    12,132Coins
    Looks good - is it the gearbox making the squeak ? Try some wd40 or grease
  5. Rodeo5150
    Antioch, CA, United States
    1,251Coins
    Arduino, 6DOF
    Try lowering the KD and Ki to get rid of that squeak that engine noise motor noise or change the Fpwm to a different frequency
  6. Dr4g0r
    Dr4g0r New Member
    483Coins
    I connected both motors and connected them to the platform but I have a problem with the direction of movement. When both motors should go up, the movement is diagonal <left side go up and right side go down and vice versa> I tried to reverse the polarity of the motor and reverse the poles of the magnets but it did not help.
    Should i change something in the code?
  7. Rodeo5150
    1,251Coins
    Arduino, 6DOF
    Okay so in Sim tools you invert the motor direction. there's a little box next to each axis and if you want one motor to go a different direction you just check that check the box next to that motor that axis and that axis/motor will go in a different direction go a different direction
    That's weird because switching the polarity should have switched the direction of the motor that's weird
    Are you sure your Motors are bidirectional
